Need Help
Old Oct 6, 2005 | 12:33 PM
quiksilverevo26's Avatar
Need Help
Friend has a 05 evo with 5000 miles on it. For some reason when you accelerate and pass 4500 to 5000 rpm's will drop 1000 rpms and then boost again. He doesn't drive hard at all and never launched it. Does anyone know what the problem might be???
Thanks in advance for your help
Old Oct 6, 2005 | 12:43 PM
bump
Old Oct 6, 2005 | 01:06 PM
anyone???
Old Oct 6, 2005 | 01:11 PM
clutch...boost leak...???...???...any help???
Old Oct 6, 2005 | 01:34 PM
Old Oct 6, 2005 | 01:35 PM
EVOL EDO's Avatar
stock? modded? drops to 1000 rpm? or drops 1000 rpm?
Old Oct 6, 2005 | 01:47 PM
bone stock...when you drive rpms drop from 5000 to 4000-4500 by its self when you're still trying to accelerate
Old Oct 6, 2005 | 01:53 PM
EVOL EDO's Avatar
does it feel like it falls on its face? id say boost leak or fuel cut. but since it hasnt been touched i dont know, if the clutch was slipping it would rev higher not lower. dont know what would cause the engine to fall down that many rpms.
Old Oct 6, 2005 | 02:05 PM
When he ask me to drive it, it would boost then kinda of lag then boost again. Pretty weird, mine never done that and I drive it like it was made to. Thanks for the input
Old Oct 6, 2005 | 02:11 PM
RyanM's Avatar
Intercooler pipe fitting from where the upper tube meets the pipe coming from the Intercooler may be loose. Check that connection. The engine moves back and forth and it sounds like its pulling something. That's the first place I'd check.
Old Oct 6, 2005 | 02:13 PM
RyanM's Avatar
Did he change the spark plugs? If he bought any kind of rapid fire, platinum +4 or splitfire crap this will happen as well. Also, if your gapped wrong this could happen.
Old Oct 6, 2005 | 03:08 PM
NOPE...Stock plugs. Like i said 5000 k on the odo. Very weird. I think you're right about the boost leak on the intercooler piping
CT9A PR
Jun 29, 2014 07:13 PM
KOOLER
Jul 19, 2012 02:57 PM
Beeboo
Feb 6, 2008 07:13 PM
Hen5000
19
Feb 12, 2007 11:12 AM
pwerks
Evo 'For Sale' Exterior Styling
53
Nov 17, 2004 10:46 AM
