cams and gas mileage - share experiences
Old Oct 13, 2005 | 08:27 AM
ev08buoy's Avatar
I wanted to know how everyone did with there cams.. 262/272/280 etc. and How they did with gas mileage after having them..
It seems my car eats so much more gas after my cams... I'm getting somewhere around 150 miles a tank boosting at 21 psi with occassional sprited driving.
Anyone else?
I know alot of people have said they get better gas mileage with cams installed but I was wondering why I'm not.. I did get tuned and was running 11.2 a/f ratio.
Old Oct 13, 2005 | 08:30 AM
anjapower's Avatar
my gas mileage improved 2-4 mpg on the highway after installing cams. I have gone as high as 29mpg with the cams in. I usually average 24 or so.
Old Oct 13, 2005 | 08:35 AM
Bom's Evo's Avatar
i average 20mpg city with hks 264's i/e
for me mpg has only improved alittle from stock.
im running a closed loop tune w/ aem ems.
try using highest octane possible and putting more air in your tires. and lighten your car from junk.
Old Oct 13, 2005 | 08:37 AM
naucrx's Avatar
My gas milage stayed about the same after I got 264 cams installed, maybe a slight increase of 1-2mpg.
Perhaps it's your right foot that's causing the problem.
Old Oct 13, 2005 | 08:41 AM
Bom's Evo's Avatar
its the 4wd eating the gas. It's hard to get around it.
Old Oct 13, 2005 | 09:48 AM
evoviiiyou's Avatar
With 264/272's if I stayed out of boost it was not to bad, but when I got into it it seemed I got gallons per mile.
Old Oct 13, 2005 | 09:52 AM
ev08buoy's Avatar
Your probably right... thats one factor another is the AWD eating my gas.
I did get ECU flashed after my cams installation however my idle is still like crap.. I know and I don't want to believe it but I'm running my BOV vented and I know it's not good I just don't have the time and money right at the moment to get rid of it because its the HKS ssq v. 2 with the upper IC pipe and I threw out the old stock upper IC... because it was just a rubber and I never intended on putting it back in.
I'll have to buy another aftermarket upper IC pipe and then grab myself another BOV to recirculate it... That will probably help big time.
The reason I don't want to believe it was before the cam install I had the BOV vented and it caused absolutely no problems.. no drivability problems, no stalling, no idling.. my car was running perfect besides possibly a little rich during shifts.
I think the addition of the cams and the BOV being vented is causing hell for my car.. anyways I'm getting off topic with the gas mileage thing.
Thanks for all your reply's.. I just wanted to see how the rest of you were running.
Old Oct 13, 2005 | 09:55 AM
evodrifter's Avatar
I just got mine in, and my gas also got better. I dont know by how much but i noticed it was better.
Old Oct 13, 2005 | 10:09 AM
dan628's Avatar
try switching to Royal Purple 10w30, I just switched to that and get like 50 more miles per tank.. I used to get only like 180, now I get 230, I was amazed!!! I drive the same as I always do.... I dont have any cams though.... yet!
Old Oct 13, 2005 | 10:17 AM
ev08buoy's Avatar
really... wow.. that's interesting.. I know royal purple is one of the best synthetic oils.
I'll def. try that.. but I might wait until my maintanence warranty is expired before I start paying for oil
Besides... its the only warranty I have left
Old Oct 13, 2005 | 12:05 PM
Ted B's Avatar
I'm using HKS 280s with an aggressive setting that enhances midrange torque, which increases efficiency in the rpm range where the engine hovers at 75-80mph.
My best experience so far has been 375miles on a tank, not hitting the reserve light until 335 miles.
Old Oct 13, 2005 | 12:14 PM
Apex Buddy's Avatar
ev08buoy, why don't you just buy the 20 dollar recirculation kit for the hks?
Old Oct 13, 2005 | 12:20 PM
gkania's Avatar
I get about 240 miles per tank with 280s.
Old Oct 13, 2005 | 12:58 PM
ninjadoc's Avatar
I'm getting 22 mpg with HKS 272 cams and a SAFC.
Old Oct 13, 2005 | 01:05 PM
Iceman2011's Avatar
210-220 with 264's
