best engine oil?
Old Oct 18, 2005 | 04:57 PM
4-BNGR's Avatar
In my car
Liquid Butter
Old Oct 18, 2005 | 05:26 PM
bd307's Avatar
Factory recommended oil is always good for your car.
Old Oct 18, 2005 | 07:12 PM
GDB's Avatar
GDB
Ester-based oil.
Old Oct 18, 2005 | 07:20 PM
i11matticc's Avatar
i think royal purple is the best, i made this point earlier but no one commented on it, mobil 1 is not a pure synthetic anymore. this all started when castrol syntec used a close to synthetic as their oil and labeled it synthetic. mobil sued castrol over this, claiming false advertising, however castrol won the lawsuit.
because of this, mobil figured if you cant beat em, join em, and decided to do the same, which is why mobil one does not say synthetic, is says syntec or some other $hit, i forgot exactly what, they did the switch over as well because it cost less to produce.
in conclusion, royal purple is the only true synthetic that i can think of off the top of my head, if anyone disagrees with me or would like to add any additional input, id like to hear about it because id be interested in hearing how others feel about this
Old Oct 18, 2005 | 07:26 PM
Spooldyou's Avatar
Boooo
MOBILE 1 ALL THE WAY
Do what the dealer says!
Old Oct 18, 2005 | 07:47 PM
romogst's Avatar
Stick with Mobil 1
Old Oct 18, 2005 | 08:35 PM
wallyevolution's Avatar
I use AMSoil every 3k
Old Oct 18, 2005 | 08:47 PM
bigmike9726's Avatar
Mobil 1...... it did wonders for my dads suburban
(sorry for the large pic)
Old Oct 18, 2005 | 08:49 PM
DCSilvrEvo's Avatar
Since ive only used Moble1 10w-30 I really cant help but i say whatever the manufacture recomends then use.
Old Oct 18, 2005 | 08:51 PM
UT_Evo's Avatar
Let's not forget to use Fully Synthetic too... Just in case people are too dumb to read the cap on the engine...
Old Oct 18, 2005 | 09:20 PM
adam5743's Avatar
I could post a lot of 2nd hand information - or just post the website where you can learn a ton about engine oil:
http://www.bobistheoilguy.com/
Old Oct 18, 2005 | 09:35 PM
GraphiteMR's Avatar
It is interested that most have recommended what is posted on the oilcap.
Mobil1 is good stuff, readily available, nuff said. As the car ages I would step up to 15w and 20w for looser clearances.
Old Oct 18, 2005 | 09:37 PM
Jin4g63's Avatar
Whats the difference between 10-30 and 5-30
Old Oct 18, 2005 | 09:40 PM
atomicapples's Avatar
mobile 1
Old Oct 18, 2005 | 09:44 PM
GraphiteMR's Avatar
weight, or thickness. 5 being lighter.
