best engine oil?
Old Oct 22, 2006 | 05:46 PM
  #76
Talon's Avatar
Mobile or AMSoil.
Old Oct 22, 2006 | 09:42 PM
  #77
srt4-Joe's Avatar
Well a local performance shop, Alamo Autosports, told me to do at LEAST a 10-40W. They recommended the Motul oil and used it for my very first time. Honestly, no real difference could be felt from changing from Royal Purple. At $10.00 a quart not sure if it is worth it, but will keep on using it.
Old Oct 22, 2006 | 09:44 PM
  #78
jroller's Avatar
mobile 1 tri syn
Old Oct 22, 2006 | 11:44 PM
  #79
EVO_JOE's Avatar
Oh s**t a year old tread. Brought back from the dead. Holloween I guess?
Oh yea Amsoil is by far the best sythetic
Old Oct 23, 2006 | 12:19 AM
  #80
evoryne's Avatar
mobil
Old Oct 23, 2006 | 05:03 AM
  #81
3SgteGuru's Avatar
Yeah I use AMSOIL but its all up to the consumer, they are all three the same AMSOIL mobil 1 and Redline. Thats the top 3.
Old Oct 23, 2006 | 11:39 AM
  #82
chekrdflag8's Avatar
Amsoil
Old Oct 23, 2006 | 11:45 AM
  #83
Airpower's Avatar
Amsoil here too
Old Oct 23, 2006 | 06:13 PM
  #84
EVO_JOE's Avatar
Mobile one is like Patron. Very well marketed yet good tequila to have shots with. But if your know the difference between what is available, you will find there is a lot better way to make a Margaritta. (Don Julio Real)
In this case Amsoil Runs and holds up better for High RPM turbo cars. Or in this case "A better way to make vicosity and Horsepower"
Old Oct 23, 2006 | 06:25 PM
  #85
Bigl4201's Avatar
wesson vegetable oil
jk obviously... mobil 1
Old Oct 23, 2006 | 06:56 PM
  #86
mdog's Avatar
Royal Purple or Amsoil for anything performance based.
Mobile 1 for the beaters and DD.
Old Oct 24, 2006 | 07:10 PM
  #87
mike127's Avatar
Any synthetic changed regularly, is better than an expensive synthetic changed less frequntly. In other words, use Mobil 1 and change it at the recommended intervals and you can't go wrong. Just my opinion.
Mike
Old Oct 24, 2006 | 09:43 PM
  #88
CO_VR4's Avatar
Most of the high visibility EVO and DSM 4g63T engines are using synthetic oil of at least 15/50 viscosity and a substantial number prefer 20/50. 10/30 is not enough.
Old Oct 24, 2006 | 09:45 PM
  #89
Dem_z's Avatar
This should've been a poll
Old Oct 24, 2006 | 10:34 PM
  #90
Evolved Monkey's Avatar
Why would you want cold viscocity to be as thick as 15-20?? That just means the oil will be even thicker and harder to pump when u start the engine cold. Oil viscocity when cold should be as close as posible to when it is warm.
