true 3" downpipe and exhaust?
Old Nov 1, 2005 | 11:05 AM
kf6ytc's Avatar
Is the DC-Sports DP a full 3" at the back flange? If so, what exhaust is also 3"? every exhaust i see is tapered to 2.75 or less for the stock cat compatability..... What are my options?
Old Nov 1, 2005 | 11:57 AM
silverEVO8's Avatar
Any 3" exhaust will bolt up to your stock cat. The only thing is that the 3" hole will overlap the smaller hole of the cat. At any rate, most if not all, will match the flange bolt holes.
Old Nov 1, 2005 | 11:59 AM
rjdEVO's Avatar
rs*r is a lil bigger than 3 inch,,,like 3 and a quarter or a li less,,can't remember
Old Nov 1, 2005 | 12:53 PM
dubbleugly01's Avatar
All the dp's I've seen that advertise 3" are a full three inches flange to flange, with no neck-downs at the flanges. It's just the cat back exhaust systems that seem to be a problem. I know the Greddy exhausts that are advertised as 80 mm do neck down at the flange that bolts to the cat (or cat delete pipe) Buschur advertises they're exhausts from the turbo all the way back to the muffler are full 3", with no neck-downs at all.
Old Nov 1, 2005 | 12:55 PM
RyanM's Avatar
The Buschur is full 3" if you get their Turbo Back system. They also have an optional system to keep your stock cat.
Old Nov 1, 2005 | 01:04 PM
EVIL_EVO_VIII's Avatar
Helix is a true 3 inch also
Old Dec 21, 2005 | 06:24 AM
Bigoj2's Avatar
What all do I need if I have the Authority downpipe and the turbo outlet and soon to get the Authority cat exhaust system?? Does is all bolt up with the factory cat or do I need a new one or go without one?? Thankyou for your time
Old Dec 21, 2005 | 06:49 AM
walkedu's Avatar
My exhaust is a full 3". No taper.
SW20Mike
Oct 13, 2015 07:01 PM
evo72man
Sep 4, 2010 03:28 PM
ttk5
Lancer Engine Tech
25
Feb 2, 2010 02:54 PM
JDW1479
Dec 17, 2008 03:10 PM
TammieNAndi
12
Nov 26, 2003 05:30 AM
