Black button on Alkycontrol control box???
Old Nov 10, 2005 | 05:14 PM
smokedmustang's Avatar
Question Black button on Alkycontrol control box???
The black "push-button" to the right of the blue dial (on/off). I see it, what does it do?
I have yet to see a flame out of either pipe. I thought I would by now, but I guess if I did see a fireball, the tuning would be off, correct?
Old Nov 10, 2005 | 05:23 PM
bolsen's Avatar
i thought you said you had crankwalk?
no fireballs must mean one of your ignition coils is too tight
Old Nov 10, 2005 | 05:33 PM
Hey Bolsen, when is your project done? hope all is well.
If you go to that post, it turned out to be an "optical illusion" one of the 4 belts I shredded, was wrapped around the pulley, and the balancer? and all my problems were from the oil balance shaft being ON THE MARKS, but 180 degrees off!!!complete rundown on other thread about the "crankwalk"
Old Nov 10, 2005 | 07:19 PM
PPI's Avatar
PPI
that small black button is a "test fire" for the alky.....lets say you have it all hooked up and you are wondering if its working or what not.....hit the button at idle for a couple seconds and you should spray alky which will cause the car to run rich and stumble. you can also use it if you unhook your nozzle from your ic pipe to test fire it or drain it (assuming you don't have much left) in the reservoir. HOpe that helps
Old Nov 11, 2005 | 02:24 AM
Yes manOfaith, that helps AND answers the question, thanks.
Old Nov 11, 2005 | 06:40 AM
PPI's Avatar
PPI
Old Nov 11, 2005 | 03:42 PM
bolsen's Avatar
Yea I didn't get to read the whole post through, that's why I just asked now :P Good to hear it wasn't bad!
My project... ehh... still waiting for parts
Old Nov 11, 2005 | 03:54 PM
platinumspecv's Avatar
Dude that's the purge button. Please press it before you use the aleky (at idle). It tests to see if the pump is working while priming it at the same time. You should go rich at idle and ur car should stumble when u press and hold for 5-10 seconds
Old Nov 11, 2005 | 04:21 PM
PPI's Avatar
PPI
/\ is there an echo in here
Old Nov 11, 2005 | 05:04 PM
Should I press and hold the button every time I start the car up? And do I keep it held for the whole 10-15 seconds?
Old Nov 11, 2005 | 05:19 PM
VTECH8TR's Avatar
NO, You only press it to check if your pump is working correctly. You do not want to press it for 10-15 seconds unless you want to flood your car. It will buck like a wild stallion .
Old Nov 11, 2005 | 05:57 PM
Thanks again VTECH8TR! I have had too many flooding problems in the past! No time for a repeat!
Old Nov 12, 2005 | 05:36 AM
Well you also want to press it to make sure its working before doing some crazy driving..right?
Old Nov 12, 2005 | 06:46 AM
RogueSTi's Avatar
DONT PUSH IT!!! IT's the SELF DESTRUCT button!
Old Nov 12, 2005 | 08:00 AM
Thats what I told my wife! I wish it was, and I wish she would PUSH IT! jk
Slewisr1
Oct 16, 2016 03:15 PM
evo8mr03
Mar 8, 2011 02:50 PM
UFO
Sep 1, 2008 02:07 PM
CatalystIX
Feb 12, 2008 06:53 PM
madfast
Future Lancer / Evo Models
Oct 4, 2007 01:01 PM
