Oil Filter Size
Old Nov 12, 2005 | 10:31 AM
Dream Came True's Avatar
Question Oil Filter Size
Hi.
I just got a PureOne Oil filter and realized a big difference in filter size. I put it on anyway but the OD of the filter is much smaller than the Mitsu stock one. The rubber seal location is the same as Mitsu's but the overall size is smaller and longer.
Is it the right size? The part number is PL14610.
Has anyone use this before?
I hope it's correct, I"m going to the Dragon in TN tomorrow.
Old Nov 12, 2005 | 01:36 PM
RiversideMitsu's Avatar
Originally Posted by Dream Came True
Hi.
Don't skimp on filters just buy the factory ones.
Old Nov 12, 2005 | 01:46 PM
modvp's Avatar
I use PureOne PL14459
http://ecat.arvinmeritor.com/smartlink/?partnum=PL14459
Old Nov 12, 2005 | 01:54 PM
modvp's Avatar
Here are the specs on PL14459 and PL14610:
PL14459:
Height: 2.95
Anti-Drain Back Valve: Yes
O.D.: 3.15
Relief Valve P.S.I.: 12-15
Type of Filter: Spin-on
Threads: M20x1.5
PL14610:
Relief Valve P.S.I.: 14-18
Height: 3.52
Threads: M20-1.5
O.D.: 2.69
Notice the height on the PL14459...it's shorter than the PL14610. The relief valve on the PL14459 is a few psi less than the PL14610. It's safe!
Old Nov 12, 2005 | 02:42 PM
Originally Posted by modvp
Thanks for the info.
I went back to the store and explained the situation. He gave me the money back and also gave me a PL14459 for free. I had to get extra quirt of oil, just to add when I spill a lot when I change it. I ended up not loosing too much.
Now, it seems like I have a slow leak. It could be from all the mess I made from the swap. I might have to take it off and re-tighten again. What a mess just to change the oil.
Old Nov 12, 2005 | 10:38 PM
BURNALL_4's Avatar
i work @ advance auto parts, ive been there for almost 4 years that pure one is an awesome filter i always reccomend that to the customers. not sure on the # off hand but.....never run any fram EVER the last tests they did they found fragments of cardboard in the engine form the filter...the last thing we need is that happening esp. crap in the fun maker (turbo). just a warning....if you believe in fram have fun ill stick to the pure one or OE. BTW i believe it was comsumer reports that did this test the pure one was rated #1
melon07
Oct 11, 2008 09:54 PM
revvin9k
Jun 3, 2008 12:35 AM
J8dailo
39
Mar 28, 2008 04:00 PM
SRTRaceR04
Apr 20, 2006 10:03 PM
Evolutionken
Aug 17, 2005 08:55 PM
