Helix 720cc injectors debut!
Old Nov 21, 2005 | 04:06 PM
Gruppe-S's Avatar
Thumbs up Helix 720cc injectors debut!
Helix 720cc injectors:
Helix Injectors are custom manufactured in Japan by a world-famous OEM parts manufacture. The injector on-time, spray pattern, and flow rate are all properly matched for maximum power and reliability. In addition, all Helix injectors are carefully flow tested to ensure identical flow rates and top quality.
Helix injectors are only available in 720cc for the Lancer Evolution. These injectors are specifically designed to aid your tuners in easy tuning for maximum power and response time.
- Helix design on time and spray pattern for maximum power output
- Manufactured by world renounce O.E.M manufacture
- Cheap and affordable compare to Greddy
- Excellent build quality compared to Lucus made injectors
- Manufacture with easy to scale and tune in mind
We have done extensive testing on these injectors in order to make sure they are easy to scale for any users. The build quality is excellent since it’s designed and manufactured in Japan. Why pay so much for Greddy when you can get the Helix for much less with the same if not better quality!!
Thanks,
Tom
Old Nov 21, 2005 | 04:21 PM
timzcat's Avatar
Do you have injector latency or battery compensation figures for these injectors?
Old Nov 21, 2005 | 05:46 PM
Gruppe-S's Avatar
Here you go:
On Time: 0.65ms / 12.5v /2.5kg/mm
Specification: Low Impedence / Top Feed
Thanks,
Tom
Old Nov 21, 2005 | 06:01 PM
timzcat's Avatar
Assuming they are calling "on time" as the latency or the amount of time it takes to turn then on, they are very impressive figures.
That is stock quality latency.
Need a tester for these injectors? I'd be happy to put them in my car and see how they act with Ecutek tuning in comparison to the PE injectors. PE battery compensation is more then 2.5 times what these are. Therefore I believe the idle and low speed driveability would be much better on these injectors. Have you guys played around with these yet?
Old Nov 21, 2005 | 06:03 PM
Nesiop's Avatar
Price.
Old Nov 21, 2005 | 06:16 PM
scott88vr6's Avatar
Originally Posted by Nesiop
Price.
365.00
Old Nov 21, 2005 | 06:33 PM
bbbwrx's Avatar
www.helix-power.com says
564-EN005 Mitsubishi Lancer Evolution VIII 720cc 2003+ $519.00
Old Nov 21, 2005 | 06:39 PM
viciousv322's Avatar
Originally Posted by Gruppe-S
Why pay so much for Greddy when you can get the Helix for much less with the same or not better quality!!
Thanks,
Tom[/B]
I think you should the the OR to IF
Old Nov 21, 2005 | 06:41 PM
Gruppe-S's Avatar
Thats the list price.
Retail is $365 shipped
Thanks,
Tom
Old Nov 21, 2005 | 08:34 PM
RazorLab's Avatar
I have them and they idle like stock. Great injectors. However, since you said you have a ECUTEK tune, your tune might have been done to your current larger injectors so your mileage might vary. I do not have a reflash but a piggyback.
Old Dec 2, 2005 | 12:17 AM
Gruppe-S's Avatar
Thanks!
Just like any other injectors, you will need to tune it either with a flash, EMS, or SAFC.
Thanks,
Tom
Gruppe-S
21
May 1, 2007 01:42 PM
Gruppe-S
35
Apr 9, 2007 08:21 PM
Gruppe-S
Jan 7, 2007 06:18 PM
Gruppe-S
14
Aug 22, 2006 09:25 PM
Gruppe-S
33
Feb 14, 2005 10:41 AM
