Boost Control Solenoid broken...
Old Nov 22, 2005 | 06:40 PM
smp3000's Avatar
One of the nipples on my boost control solenoid (capped off becuse of MBC) broke off this week and it's causing some crazy stuff. At first it was causing fuel cut, and then threw the overboost code- P0234- I think the code was.
Anyways, I have taped it off but it doesn't seem to be fixing the issue. I will likely need a new one.
Anyone know the cost on these? Anyone have a spare? lol
Old Nov 22, 2005 | 06:48 PM
Anarchy99's Avatar
If you caped it off it is not getting any Boost to it, i think you have another issue going on there. you took it out of the loop.
Old Nov 22, 2005 | 06:52 PM
HiRevnVIII's Avatar
if you really want to make sure its not reading anything, why not just caulk the hold or superglue it or something. I think you have a different issue though, but this may help.
Old Nov 22, 2005 | 07:00 PM
smp3000's Avatar
Well both barbs were capped off, but one broke this week so it isn't exaclty capped anymore.
I sure hope it isn't another issue... Any ideas? All other vac lines are ok, and the mbc is set.
The only thing I can think is it may have something to do with the SAFC settings and the weather getting about 20 degrees colder.
Old Nov 23, 2005 | 10:25 AM
smp3000's Avatar
I found a 2G DSM solenoid on ebay. Wonder if that would work?
Old Nov 23, 2005 | 10:31 AM
dubbleugly01's Avatar
you boost solenoid does not have a pressure sensor in it, it's just a solenoid that toggles open/closed based on another sensor. If you broke a nipple off of it, that would not cause any of your driveablility problems. this is the solenoid under the factory airbox?
Old Nov 23, 2005 | 11:07 AM
smp3000's Avatar
yes... I just sealed it with some marine grade sealant. While I was at it I also noticed all of the caps I used to cap the vac lines were deteriorating. This could be the cause of the boost issues. Vac leaks suck...
The fuel cut most likely has to do with the weather getting colder and my SAFC settings. Anyone agree?
WhiteHat
Mar 24, 2016 01:25 PM
babaz7
Mar 13, 2016 06:38 AM
RS200
Jan 23, 2016 04:19 PM
Ryan4dc
Oct 11, 2013 03:08 AM
woodc
Mar 9, 2006 12:19 AM
