bad front diff Q
Old Nov 24, 2005 | 10:27 AM
redevo8driver's Avatar
bad front diff Q
My friend thinks he might have a bad front diff or that his transfer case is going bad. What are some signs of this happening? How do you know for sure if its bad?
Old Nov 24, 2005 | 10:38 AM
Evolving-04's Avatar
It will be whining really bad. Mine would be ear piercing and like a set speed (55mph). I don't think you can check it youself. Send it to sheperd or tre and get a lsd if you have to fix it anyway then it will help stop it from happening again.
Old Nov 24, 2005 | 11:22 AM
thadon84's Avatar
Jack the front end of your car so that your wheels are off of the ground rotate roll either wheel forward or backward and the other wheel should freely roll in the opposite direction as the one you are rolling with no problem. If that works your front diff is ok, I dont know how to check the center diff though
Old Nov 25, 2005 | 02:52 AM
trinydex's Avatar
if you need a new front diff... i have one.
Old Nov 25, 2005 | 08:49 AM
soundfx007's Avatar
Youll know if its broken, just try and make a turn left or right. If its poping and grinding and jerkin its a broken front diff. Ive got one fs too if you need it.
Old Dec 18, 2005 | 09:45 AM
nothere's Avatar
what would cause a broken/bad front differencial?
mine has started very light popping and a grind/vibrate going round tight corners at low speed.
Old Dec 18, 2005 | 10:07 AM
chmodlf's Avatar
If you need a front diff I have a mint one for sale. PM me
Here is the ad:
https://www.evolutionm.net/forums/sh...hreadid=174966
Old Dec 18, 2005 | 10:51 AM
SuperHatch's Avatar
A whining transfer case is not the signs of a bad diff, but rather of a bad ring and pinion set. If the R&P gears are whining then it is most likely due to bad fluid, low fluid, incorrect fluid, or misaligned gears from the factory that caused accelerated gear wear.
A bad front diff, as stated above, will show its signs in turns from a popping, cracking, sound. When driving in a straight line the spider gears are not turning at all, so there will be no noise generated by the damaged gearset. If you jack up the car and turn one of the front wheels and the other doesn't move the other way, or if it's impossible to turn the wheels, those are pretty definate signs.
- Steve
Old Dec 18, 2005 | 10:52 PM
NDgsx's Avatar
I've seen a lot of underfilled transfer cases, make sure you're adding the full amount mitsu recomends.
If you have an question on whether the replacement fluid you get is hypoid compatible just stick with
Old Dec 22, 2005 | 08:44 PM
trinydex's Avatar
if it's at low speed also check your rear diff... if you don't have the proper firtcion modifyers in the fluid you will get audible and feelable vibrations. i also have a front diff for sale :]
Nasty Evolution
Oct 28, 2008 01:13 AM
EVO8LTW
Oct 15, 2007 12:54 PM
19psi
16
Oct 5, 2006 10:44 AM
QwikEVO
15
Jun 29, 2006 12:43 PM
j-evo8
10
Jul 7, 2005 08:20 PM
