Found the problem w/ my car, really bad
Old Nov 30, 2005 | 01:33 PM
lemacfar's Avatar
Umm so after changing the BOV 3 times, checking all the vacumm hoses etc etc
plugs, pipes check etc etc etc.... taking the utec out etc etc etc
i think i found my culprit... it seems my crank pully wobbles under idle (or a lack therof flucation galore)
And my shop told me that the scanner reads a crank sensor fault....
How expensive does everyone think this would be... i have no cams or nothing that would cause this problem.
Everyone think dealer will cover this?
If not what about insurance under comp...
Old Nov 30, 2005 | 03:44 PM
05SilverEvoVIII's Avatar
Wow havent heard of one of these going wrong yet.
Best of luck to ya!!
Old Nov 30, 2005 | 04:51 PM
WHTEVO's Avatar
that is pretty odd that your pulley is wobbling. on such a new car i wouldn't think the rubber part of it rotted out. i have only seen one pulley do this but it was on a 1g dsm. i would try to get the dealer to cover it if at all possible unless you can pull the sensor yourself. you will need to get behind the timing belt at the crank to even get to the sensor. is it possible it is unplugged behind the valve cover? usually those won't get ruined unless the trigger plate hits it and if it does that you would hear it hitting it when rotating the engine.
did this just happen all of the sudden? are the 4 12mm bolts that hold that pulley to the crank sprocket tight?
good luck and keep us updated.
Old Nov 30, 2005 | 06:00 PM
sleet's Avatar
Put the car back to stock and take it in and tell them to fix it, DONT SELL IT!
Old Nov 30, 2005 | 06:09 PM
ray3328's Avatar
Agreed
Old Nov 30, 2005 | 07:50 PM
bolsen's Avatar
Yay, more people advising other people to ruin valid warranty claims.
You pay to play kids...
(To the original poster, I see your sig, but I also see you "taking the utec out"...)
Sorry to be a kill joy, but it's the honest thing to do.
Old Nov 30, 2005 | 09:44 PM
Fourdoor's Avatar
You seem to have crank walk. This is where the crank shaft has too much play axially, it moves back and forth in the block. This was a rare occurence in early DSM's, but became a huge issue in the 2G DSM's. I have heard of one other case here on Evom of it happeing in an EVO. If you have an aftermarket clutch Mitsubishi will blame it for the problem and not cover the repair under warrenty.
Keith
Old Nov 30, 2005 | 10:13 PM
talentsearch301's Avatar
What were the symptoms/problems, before you found the actual problem?
By the way...Im the other guy diagnosed with crankwalk
Old Dec 1, 2005 | 12:15 AM
bacalhau16's Avatar
this is the case i remember reading here on evom.
https://www.evolutionm.net/forums/sh...ight=crankwalk
talk to the person who started this thread and see if he can help u!
Old Dec 1, 2005 | 05:41 AM
After extensive troubleshooting...it was found out that he didnt have crankwalk
Old Dec 1, 2005 | 07:12 PM
bacalhau16's Avatar
oh sorry about that then!
kaj
17
Jul 20, 2016 08:03 PM
VOridin
Mar 25, 2013 05:15 AM
TurbotrixRacing
AEM EMS
43
Dec 10, 2012 02:31 PM
cheb evo
E85 / Ethanol
Sep 16, 2010 04:31 PM
BOOSTEZ
24
Sep 20, 2007 08:55 AM
