Retuned after cam / gears install 33whp gain!
Cam gears are the next best thing to totally custom-made camshafts. A good compromise.
Especially useful when your overall operating pressure ratio (intake/exhaust static-pressure ratio) is unknown or different from the exact setup your cam manufacturer used when designing the cams.
I'm sure a large part of the Evo 9's performace is the result of its variable cam engle MIVEC system. That way you can have conservative angles when cruising and aggressive angles when running hard. Good stuff.
Originally Posted by USAF_STi
Hey this is off topic. i was at a car meet tonight and a guy who was there was claiming 330WHP on a stock STi VF39 turbo on your dyno. is this true? he was in a 04' blue STi with a carbon fiber hood and gold rota tarmac 2's. i just wanted to know because i thought he was BS'ing. thanks. Brett
Mike
Originally Posted by gunnerman
try setting -1/-4...i i heard that works really well with 272's in/ex.
I tried -4/-1 like people have been saying and it was actually a little worse than 0/0 on my car. I lost low end and the top end didn't change at all, at least according to the dyno curves.
how much did they charge for the cam install? im thinking about upgrading to 280's. also what did you use to tune. i get my safc tuned by gruppe-s. i guess the 10.5 on the 05's really do make a difference.
I tuned it with a ECU plus: http://www.ecuplus.com/
Originally Posted by Gruppe-S
For those of you that thinks cam gears doesn't work....we have proved that it does work today.
I've proven to myself without a doubt that this particular application responds favorably to a relatively tight LSA, which is what you get by slightly advancing the intake and slightly retarding the exhaust cams simultaneously (as was done here). You have to be careful though because it WILL be less tolerant to detonation as a result of poor fuel and/or poor tuning.
The improvement in power seen here just from the mild change in cam timing is roughly the equivalent of 10whp and 6ft/lbs as measured on a Dynojet, and this can probably be improved further. The difference I've seen with HKS 280s is even greater.
Why is that? I am still getting my head around this combo so I would love to hear why.
Originally Posted by MPJ Performance
Brett, he probably read his dyno sheet wrong perhaps his car was dyno'd at 3:30pm and he got the time confused with WHP as no vf39 car on any octane fuel has made over 305whp on the dyno (305whp being Sunoco 104 fueled car).
Mike
Mike
Originally Posted by hotrod2448
How was the ECU+ to work with?
ECU + logging is great, the logs are clear and easy to read, super fast, coupled with a external wideband wired in to log as well, and knock voltage, probably one of the better piggybacks out there. IMHO.
Once I get boost logging hooked up and once Tom gets boost control (hint hint Tom) it will be even more amazing!
FS[West]: 2005 Silver Evo MR w/ 5speed swap (CA)
razorlab
For Sale - Cars For Sale
Jun 4, 2014 06:27 PM
