Do MAFs adjust richer as gears go up? Tuners & members please respond: Truth Squad
#121
Originally Posted by Ted B
No one in this discussion ever implied that speed density presented driveability problems (temperature doesn't present an issue anyway), which are entirely dependent on the accuracy of the programming. As far as I am concerned, the crux of the discussion was to illustrate the advantages and disadvantages of each.
To the best that can be ascertained from observations here and in the real world, it makes sense to go standalone when either:
(1) The factory MAF cannot be made to effectively meter the existing airflow;
-or-
(2) The additional logging capabilities prove to be worth the cost.
Until or unless either of those conditions are met, it's an optional expense.
-or-
There are a lot more factors involved when making a decision to go stand alone than the two you mention. I feel another thread should be started to discuss this.
#122
Originally Posted by Richard Sierra
I thinks it is safe to assume it's not the "inferior" load system as thousands of speed denisty cars run just fine.
If you are inexperienced with stand alones it will take a lot of time and you may have to retune.
Shiv
#123
You implied that a MAF system will out perform a MAP based system on a street driven car. Driveability is most certainly a part of a vehicles performance.
Raceghost
Jun 1, 2016 12:30 AM
