what is this noise at high speeds?!?!?
Old Dec 18, 2005 | 07:15 AM
ev08buoy's Avatar
When I had an Evo.. on my first stage of mods.. which was boost guage, mbc, intake, exhaust set up.. I too was running at full throttle and noticed my boost hitting 25-28 psi.
Now I never actually went on local highways and started doing 110mph but I sure did get from 0-70 pretty damn quick, Ofcourse I didn't hear noises like you but anyway.. I went to have my car dynoed and when they plugged in there boost guage it had accurate readings and I was boosting 20psi.
I had a defi d guage by the way and I'm pretty sure those are known to read so many psi off... but that's what you get for a 100 dollar guage.
Old Dec 18, 2005 | 07:17 AM
Warrtalon's Avatar
$100 isn't cheap for a gauge. Even if it was $30, it should read the correct boost, not 5-8psi off. That's unacceptable and not normal.
Old Dec 18, 2005 | 09:18 AM
phatman2600's Avatar
It was the shop 909 Motorsports that installed it. I am going to go and give them hell. I know I'm pretty sure I wasn't running 25 psi, I would have felt 25 psi. That boost gauge intallation must be wrong too. What should I tell 909 Motorsports?
Old Dec 18, 2005 | 09:20 AM
BaLListic_EVO's Avatar
really i dont think you would feel 25psi on pump gas basically it would end up pulling timing from all the detonation..... it would probally run worse....
Old Dec 19, 2005 | 06:19 PM
Evoryder's Avatar
you would feel 25psi in a evo...you'd know for sure....
i had a crappy "autometer gauge" that read 5psi more than it was ...for the longest i thought i was running 21 psi when i was really running 16psi...my profec b spec II saw to my boost being corrected... autometer gauges are known to be defective and dont' last too long...
Mackman
Jul 30, 2024 07:51 AM
s2h757
Apr 6, 2017 06:30 AM
shane_evo7
Nov 11, 2016 09:23 AM
cerealkeller
Aug 14, 2016 08:24 AM
