ACD Article - Answers for everybody!
its getting really cold here in ID, and i have noticed that when i start the car in the morning the ACD has the 3 solid lights
But when turn off the car and turn it back on , 3 solid lights are gone and am back on 'Tarmac' Mode
is it something i should be worried about ? or is it normal on a cold start?
Can somebody please clarify whether the torque split is 50:50 or if it varies? I know the ACD does not change the torque split but in this Tech Article which was referenced the article mentions two torque splits, 30:70 and 50:50 front:rear. In a few of the other articles it mentions the base split is 50:50 (meaning it can change from the base split?). Does that mean then that the ACD unit is auto-controlling the torque split between 50:50 through 30:70 as it sees fit? at the same time it is "(un)locking" the differential as well?
Basically, what it says is that a 30:70 split provides emphasis on maximizing cornering. 50:50 is for when you want to emphasis on traction and stability. Therefore, they decided to go with a 50:50 split.
The split numbers they are referring to is the base split of the gears. I.e. the teeth on the center diff gears provide a 50:50 split.
I hope this makes more sense for you.
Terry S
I think I worked it out...
In locked mode it becomes 50:50
In free mode it becomes an open diff - the torque goes to where ever it needs to go eg to the front/rear wheel pairs are free to spin independently (since the front tyres have more distance to travel than the rears)..... the rear diff looks after the L & R rear torque split.
So it's always AWD - just distributed differently.... never FF or FR for an instance unless you have both rear wheels off the ground or something
Just like an open rear diff on a RWD truck is not Left or Right drive, an open center diff on the EVO does not really make the car front or rear drive.
So when the ACD is open (eg turning), the diff is free to function, so it allows the front and rear wheels to spin at individual rates - why is the torque that fixed at 50:50?
When the ACD is locked, doesnt it suppress the diff function and therefore not allow the rear and front wheels to spin independently hence a 50:50 torque distribution?
http://www.driven2modify.com/showthread.php?t=5436
hmmm confused!
I think it's just that those convenient little front/rear ratios and percentages don't really apply here. When it's open during normal driving, there is no wheel spinning or intelligent power distribution going on. When it locks up after sensing a bit of spin, it's just locked and there is no intelligent power distribution going on either...although I think it is safe to say there is a 50:50 power distribution during this time.
Just my opinion, and I could be wrong.
You guys are getting this totally backwards.
When the clutch pack is not engaged, you have an open differential as your center differential. Go to www.howstuffworks.com and read about open differentials. An open differential geared to 50/50 like ours is will ALWAYS have equal amounts of torque on each side of the diff no matter the difference in wheels speeds. It's all about how gears work. You are confusing wheel speed with torque I think, and they are not the same thing.
Weld the center diff together so you have a solid axle between the front and rear, ie, there is no center diff OR look at it like the clutch packs have locked together (both scenarios are the same thing). Where is the torque going to go if the front is on tarmac and the rear is on ice? All of it will go to the front, because THAT IS WHERE THE GRIP IS. If the situation is reversed, all the torque will go to the rear. While the front wheels and the rear wheels are spinning at the same speed in this scenario and it "LOOKS" like the end on ice is doing something, really the end with the grip is doing all the work. There is no computer moving the torque around. It's all mechanics/physics. Get it?
Trying to get my head around this....
hmmm confused!
hmmm confused!
If the rear wheels are on a low traction surface with the diff open, whatever little bit of torque is put to the ground in the rear will also be evenly applied at the front. For example, if the car can only put down 100 ft# due to low traction in the rear, it will put down an even 100ft# to the front also.
If the rear wheels are off the ground (zero traction) with the closed diff, ALL of the torque (100%) will be put to the ground by the front tires, at least up to the clamping limit of the diff.
In reality, though, the car never exists in either of these states. It is always shifting and moving around as wheels gain and lose traction and the diff locks and unlocks. . .
EVOlutionary
so....
free ACD = open diff
torque is 50:50
but the diff allows the wheels to spin at different rates (like a LSD)
so in cornering allows the front wheels to travel more than the rears
locked ACD = supressed open diff function = in equivalent like having no diff
torque still 50:50
so hard braking/accelerating adds stability by varying the degree of 'freeness' of the ACD to balance fulltime AWD stability vs allowing the wheels to spin at different rates....
torque is 50:50
torque still 50:50
