ACD Article - Answers for everybody!
Old Jul 12, 2011 | 12:30 PM
  #301
Teal2nnr's Avatar
Originally Posted by krazykorean84
Its possible over time. There may be air in the system. If you get it to a garage or bleed it within a couple weeks you should be ok. Have you done anything recently that involved disconnecting an ACD fluid line?
Ya i just swaped in a built T-Case......
Old Jul 12, 2011 | 01:18 PM
  #302
krazykorean84's Avatar
Search how to bleed ACD or take it to a shop that can do it. Since you had the fluid line disconnected you'll definitely need to bleed it. Good luck.
Old Jul 26, 2011 | 02:55 PM
  #303
rsonistxl's Avatar
can i add ACD to my 03 evo 8?
Old Jul 27, 2011 | 10:37 PM
  #304
ICEMAN99TURBO's Avatar
Sure... if you want to go broke doing it.
Old Jul 28, 2011 | 04:57 PM
  #305
rsonistxl's Avatar
lol i was planning on selling my car and upgrading by next year
Old Aug 3, 2011 | 07:01 PM
  #306
..Well, then, no worries.
Old Sep 4, 2011 | 03:07 PM
  #307
mooboy's Avatar
So for those of you that occasionally hit snow... Is it worth it to have ACD? I am trying to decide between 03-04 or more expensive 05-06...
Old Sep 4, 2011 | 08:37 PM
  #308
^^^Get the EVO9 w/ the ACD & the MIVEC
BTW, Read every page of the thread. Definitely picked up some understanding on how the drive trains works
Wonder why the thread is not stickied anymore
Old Sep 4, 2011 | 10:56 PM
  #309
mooboy's Avatar
Of course I would love the newer car. But man the EVO VIII is soooo cheap right now.
Old Oct 23, 2011 | 10:08 PM
  #310
DREAMRACER's Avatar
I have a 06 evo IX Mr.
The ACD Lights just started coming on after i got some body work done on my front end. The body shop replaced the radiator and a couple other things.
i picked up the car and didnt notice that the ACD light was on until i left the body shop 3 hr later and they where closed. i drop it of and there was no sign of the 3 lights. i even took a picture of the dash before i brought it in.
So all in all i started hearing this intermittent buzzing sound for 3 seconds after coming to a stop then it goes away.. when i start the car only 1 acd light is on.. n i am able to cycle through all 3 modes. i drive off still only 1 light is on.. cool.. then i look again after making it a few block and the all 3 lights are on..
has anyone had this happen and what is the fix?
Old Nov 18, 2011 | 03:22 PM
  #311
utripin's Avatar
Check to make sure all of the white wires with red stripes are hooked up to the positive side of the battery! Fusible links.....
Old Nov 19, 2011 | 05:34 AM
  #312
utripin's Avatar
Talking
One of these wires are a big player with the power to the ACD , and a hell of a lot of other electrical stuff! Ask me how I know!
Old Feb 28, 2012 | 03:05 AM
  #313
rhd-jon's Avatar
Dam great write up.
Old Jun 11, 2012 | 09:47 PM
  #314
Monkeysphere's Avatar
So when I start the car in my garage the ACD lights are all as they should be. All 3 come on at first then clear and stay off the whole time the car is running no matter what I do with it. Return home, park in the garage the next day it is fine.
But then the problem, if the car is parked on any kind of an angle, even just on the side of the street, it does it's 3 lights then I start and it clears. A second later all 3 come back on again. If I move the car to a flat and level surface and turn it off, let it sit for a minute then start again and all is well.
Off to Mitsubishi or is this a more simple problem someone has encountered before?
Old Jun 12, 2012 | 06:51 PM
  #315
GG06MR's Avatar
^^^ What's your ACD reservoir level at? Just curious if it's just low enough that an incline/decline is enough to trip it off.
