42R Boost Levels
Originally Posted by BadazzCR
It has been done before...
Saying GT35 is like saying T3/T4. There are so many wheel options that you can have equipped in the 35R housing. Saying that all 35R's are a 65 lb minute wheel is like saying all t3/T4's are a 50lb wheel. I happen to know for a fact that 35/40 hybrids are possible and sometimes are still just called a 35.
I have that FP3065 on my Evo and I think about 33 psi is all she has. Anymore boost does not equal any more hp, on my evo anyway. I just cannot see 45 psi on this turbo doing very much more than say 35 psi, which is still innefficient. Like you said live and learn.
Originally Posted by CBRE
On another note my old race car trapped 148.5(at the DSM shootout in Norwalk on a hot day) running mid 45psi on a GT30 from FP(FP3065), maybe if I would have run less boost it would have gone faster, live and learn.
Please correct me if I am wrong.
when it dynoed 540whp + 100shot it went 10.09 @ 147 sputtering the entire way down the track (DSM Shootout 05, he won the Quick 16 class). 1.3sec 60', it was 9.70-9.80 capable that pass. i did forget to mention that on the dyno there was a 100 shot of direct port nitrous involved, when it put down 760. but was never run @ that hp level because of block issues.
Makes sense now.
No need to get defensive. I have no tone in my post. Doug answered the question for me. I was under the impression that the airflow rating was a theoretical measurement based on a specific psi (typically 1bar) and a specific temperature. The airflow measurement does not have a direct correlation with WHP although it is funny that seems to work out that way alot of the time.
Another thing, the calculated air flow number is not the be all, end all when it comes to power production. Example: 390cfm restrictor on a NASCAR that makes 600hp. God help me for using a NASCAR example.
Originally Posted by Ronin17
Go read what I said, I don't know if I've ever seen a car put out more WHP than the airflow the turbo is capable of flowing. Evo 8 turbos flow 42 lb/min, I have seen plenty of logs of people flowing more air than a turbo has been rated for, but not 10 lb/min more. Are you saying that you've seen people make over 420 WHP from the stock turbo?
Originally Posted by evoviiiyou
Does anyone know the max boost that a GT42R turbo can handle, before it starts to be inefficient? It seems that a GT30R runs out of juice at around 30 psi, GT35R maxes out at around 35-37 psi, etc....
Guys turbo's will can run diffrent amounts of boost on diffrent engines...
Say you have two identical gt35r turbo's
Put one on a evo8
Put one on a 4.6L gt mustang
You probably can push about 42 to 45lbs of boost to redline on the evo..
But only 32 to 35 on the mustang...
More displacement = more air flow = harder for turbo to keep up..
Put one on a evo8
GT3582R = GT35R, GT3076R = GT30R, GT4294R = GT42R. This is going by how Garrett names the turbos. GT35 doesn't refer to a specific turbo, but GT35R in this case does.
Originally Posted by GTREVO
Yea...but its pointless... I've got a GT3567 ( T04R 67 mm compressor wheel) rated at 76lb a minute airflow. Its not a mismatch and its a hybrid but I got no more horsepower with it running even up to 40 psi.... MOdifying the standard 35R compressor wheel is a waste of time and money... A T3/T4 is a different thing altogether... going from a 50 trim to a 60 or 60-1 does give you a flow and power increase...
Call Forced Performance or Innovative and ask if there are more than one option that fits in the 35R housing. 35R does not refer to a specific wheel.
A turbocharger is still a turbocharger independent of the frame and bearing style. You can put any wheel in any housing, its a matter of time and money and research.
badev0
Oct 21, 2015 06:09 AM
