PO234 code throwing
Old Jan 9, 2006 | 10:45 AM
nigletsyz's Avatar
PO234 code throwing
Just hooked up a Forge MBC this weekend and took it out for a test drive. Looks like I'm hitting boost cut at around 1.3 bar ~ 18psi on WOT at around 5.5 - 6k RPMs. Checked the code at Autozone and it gave me the PO234 code: Turbocharger Wastegate System Malfunction / Engine Overboost. Why am I overboosting at 18psi? the MBC is turned all the way down, hooked up to the wastgate and tubine outlet. BCS is bypassed, still plugged in. If I adjust the BOV to a higher pressure would this help? Or should I just wait until I get custom flashed next week to solve this problem? Thanks for any input.
Old Mar 9, 2007 | 03:07 PM
jezefink's Avatar
bump/.....having the same problem
Old Mar 9, 2007 | 05:39 PM
sonicnofadz's Avatar
Make sure that the boost solenoid is still plugged in, and disconnect the negative terminal on the battery to reset the ECU. Other than that, I have no clue
Many people fix this problem by going to get a tune.
twinspoolin94
Oct 15, 2015 05:28 AM
boomn29
For Sale - Part Outs
74
Jan 15, 2013 09:12 AM
jesterEVO
Jul 2, 2009 11:30 AM
McDougal
Jun 15, 2007 11:59 AM
bigjhoney
Mar 15, 2005 01:45 PM
