Say no to ARP.
Old Jan 15, 2006 | 01:45 PM
Evo_Jay's Avatar
Originally Posted by Mercenary3
Some people think that the best way to get a reliable car is to put the best products in it. Thats only half the equation. Its also about minimizing complexity.
+1
Originally Posted by nickracer9
i don't understand why you are complaining about arp's product when you didn't even install them right. You knew there where risks involved by installing them one by one. the topic of this thread should be "say no to installing one by one".
+1
Old Jan 15, 2006 | 02:07 PM
KTT's Avatar
KTT
Why not blame Mobil? After all they made the oil that is leaking out of the head gasket....
Old Jan 15, 2006 | 03:38 PM
hel_if_ino's Avatar
Originally Posted by justchil
Dang ARP making you install those headstuds improperly
Seriously tho.. why bother unless your doing something else like installing cams?
Improperly my ***... show me where it says this method is "unapproved," otherwise unless its from ARP's mouth, which I dont think you work for, then you need to keep your mouth shut. If this method is an approved method for seaworthy components on a nuclear submarine (which I spent five years on) which go to depths in excess of 700 feet, with my life on the line, I am pretty sure its a noteable method. Now as for the re-torque, we should really find out from ARP what the "suggested" number is, because I just installed mine last night, and I definitely do not want to run into this situation. This man did nothing wrong, and for the record ARP's directions say 75 ftlbs when using ARP moly lube.
Old Jan 15, 2006 | 03:40 PM
Ultimate CC's Avatar
I did mine at 75lbs and didn't retorque, I have since put on 1500 hard *** miles and its still holding up strong, but who knows maybe I should just retorque them when I get a chance
Old Jan 15, 2006 | 03:45 PM
hel_if_ino's Avatar
Eh, its a bit of a pain, but might as well... JUST to be sure, you know? I wasn't going to either, but I dont need this kind of problem on my plate, so I will probably end up doing it just before the Atlanta dynoflash meet.
Old Jan 15, 2006 | 03:47 PM
hel_if_ino's Avatar
Also, I just put in an email to ARP tech regarding this situation, and the suggested number of heat cycle/re-torque requirements there are, so we shall see.
Old Jan 15, 2006 | 03:56 PM
evolved4g63's Avatar
When doing an install like this remember there is always a chance of something going wrong. There was a thread about this a year or two ago. I think someone from Turbotrix had wrote not to do the 1x1 method. Because of a number of variables. Also remember when doing them 1x1 you are still breaking the factory seal. I guess it could be a 50/50 shot of nothing going wrong (maybe better maybe worse.) If it aint broke dont fix it kinda thing. Also i thik Nate from DSMotorsport had run about 35psi with a 35r before the stockers had streched.
Old Jan 15, 2006 | 03:57 PM
Sounds good keep us updated, yea its not a problem for me to do it, I have a shop but its just been so busy, maybe when things slow down I'll redo em
Old Jan 15, 2006 | 04:17 PM
hotrod2448's Avatar
Everything I've ever read on tightening head bolts or studs starts with all the bolts loose like you had just laid the head back on the block. Then tightening them to a certain low torque spec staring with the bolt closest to the center of the head and working your way out in a clockwise pattern. Then stepping up to the final torque and tightening them in the same pattern.
I think pretty much everyone agrees the 1 by 1 method is a shortcut that may save you time or may not if you have to re-do the job.
I definitely would not blame ARP for your problems as thread title makes it sound.
Old Jan 15, 2006 | 04:18 PM
FLAEVO's Avatar
I did the one by one ,followed mits. torq.specs for replacement order. I used apr lube
torq to75lbs ,never retorqued.I did this at 16000 when I did the cams. Now I have
a GT35R running 28 psi did that at 47000 mls. Today I have over 59000 mls on it with
no head gasket problems
Old Jan 15, 2006 | 04:27 PM
elhalisf's Avatar
i torqued mine to 90 ft-lb (a little high) and didn't retorque. i had to replace the short block, so i got a new gasket and checked the head for flatness. it didn't need to be milled.
Old Jan 15, 2006 | 06:42 PM
MaxR's Avatar
he has a bad torque wrench. end of story.
Old Jan 15, 2006 | 07:05 PM
DSMotorsport's Avatar
I said I wan't going to change to ARP head studs untill I had to. Ended up stretching the stock head bolts runing 35psi on a GT35R making about 530whp. The stock HG blew out the middle layer (stock 3 layer metal hg). IMHO it's a risk to change them 1 at a time, and no reason to do it unless your pushing serious power (certainly no risk with stock turbo). ARP's are not going to save your HG from a tuning mistake and detonation, so why change them before you are at the limit of cyl pressure that will stretch stock bolts.
Have you pulled your new ARP's and confirmed they are indeed stretched? That's the only mode of failure for a simple thing like a bolt. If the ARP's are still in tolernce for length, then it was an installation error that blew your HG, not the ARP hardware failing.
There is always a risk with HG sealing, I have had new gasket with ARP's torqued to spec on freshly cut head and block surfaces not seal. Why? spec of dirt, mistaken click on torque wrench? defect HG? scratched head on reinstall? Just saying that poor results happen sometimes even when they shouldn't, and it's ususally not the fault of the product.
Pull all 10 studs out and prove one is stretched. If there not, you have noone to blame but yourself for the HG leak.
Old Jan 15, 2006 | 08:25 PM
Evo8RA's Avatar
Old Jan 15, 2006 | 08:55 PM
C6C6CH3vo's Avatar
Aren't those changed as a replacement for doing other work on the engine that require their removal?
