For those who installed cams.
Old Jan 19, 2006 | 11:41 AM
  #31
walkedu's Avatar
I didn't do headstuds on my cam install and so far so good. It's been about 4 weeks since with not so much as an oil leak. I even bought them, then decided not to put them in. I don't plan on getting a bigger turbo (AutoXing, not drag racing), so i opted not to risk messing anything up doing the "one by one" method. There are plenty of BIG TIMERS on this site that would agree that your stock bolts will hold just fine.
If i had to do it all over again, the only thing i would do different would be use the cam tool. It'll help out a butt load.
Old Jan 19, 2006 | 01:22 PM
  #32
Curt@MrLed's Avatar
Former Vendor
the standard i have seen for studs is running over 23 psi, or severe track use, with constant and prolonged high boost running.. again no need to remove the head for stud installs.. these are studs not bolts.. one by one has worked for tons.. as long as you heat cycle them..
Old Jan 19, 2006 | 02:27 PM
  #33
NIevo's Avatar
Originally Posted by use2vtec
GO to this link right here : http://www.otctools.com/frames-newcatalog.php3Type in Belt tensioner in the search bar. Scroll down and go the first one I believe its 6001 and that is the one you want. I bought mine from here last year for 8.55 plus shipping. I believe you have to call and place your order on the phone. Hope that helps.
So this works for our motor? It says its for the 2.4l but if it fits then.
Im not planning on doing the headgasket because most people agree that the stock one is best anyways.
The reason Im doing headstuds now is beause I'll have the head off to do the cams anyways and I'm planning on adding alky this summer. Thanks for all the help guys. Now if I could just get some for my headlight blackout ?'s
Old Jan 19, 2006 | 03:25 PM
  #34
sandm's Avatar
don't think you need to take the head off to do cams?
I wasn't planning on taking it off.
do the headstuds one at a time as detailed in the how-to sections. takes about an hour.
  #35
Ultimate CC's Avatar
you don't need to take the head off to do cams, just the valve cover
Old Jan 19, 2006 | 03:32 PM
  #36
sandm's Avatar
yea, I didn't think that you want to break the head gasket seal if you don't have to. change cams and do the studs using the one at a time procedure.
Old Jan 19, 2006 | 03:50 PM
  #37
NIevo's Avatar
Oops, I meant take the valve cover off. Alittle difference I guess!
Old Jan 19, 2006 | 04:25 PM
  #38
Curt@MrLed's Avatar
Former Vendor
also do your studs in the tighten down sequence as found in the shop manual..
Old Jan 19, 2006 | 05:01 PM
  #39
C6C6CH3vo's Avatar
Originally Posted by NIevo
I am getting ready to do my cam install following the EvoMoto write-up and was wondering if those of you that have done their own if they had anything to add to it that they found was easier.
1) Bleed lashes (lifters) or some will internally rupture afterwards
2) Use Ultra Black sealant from Advance
3) Breaking loose the cam sprocket bolts is tough
4) Just buy the tension tool ($30) - You absolutely have to turn it slow like 1/4 of a turn at a time/wait, and if you feel it bind, you jammed the mechanism.
5) Take your time. I hear people bragging on doing the job in 4 hours - I spent about an hour or two just cleaning the surfaces and prepping for sealant.
6) I don't know about headstuds
Old Jan 19, 2006 | 05:23 PM
  #40
SeanJhn9's Avatar
Originally Posted by sandm
they are def. not fast. what are you having done?
i'm gettin my hks 280's put in, as well as injectors, forge WG actuator, and maybe my meth kit, i'm not sure if i wanna sell it or keep it yet
Old Jan 19, 2006 | 06:46 PM
  #41
NIevo's Avatar
Where did you get your Tension tool from? $30 is cheap.
Old Jan 19, 2006 | 06:49 PM
  #42
needasrt4's Avatar
thanks for the info
Old Jan 19, 2006 | 06:50 PM
  #43
forbidden color's Avatar
i would check road race engineering site for their tips on installing cams.
Good information on that site.
Old Jan 19, 2006 | 08:20 PM
  #44
jojipoji's Avatar
30 bucks is cheap
Old Jan 20, 2006 | 06:10 AM
  #45
use2vtec's Avatar
Yes this tool will work. I used it and it worked perfect. For those that dont know what im talking about this is the timing belt tensioner tool. It only costs 9 bucks plus shipping. Here is the link again for those that misssed it http://www.otctools.com/frames-newcatalog.php3.
1. In the search bar type in belt tensioner
2. Scroll down to the first one provided #6001 and that is the one you want to get.
