Spark plug help !!
Old Jan 22, 2006 | 02:46 PM
evoracer32's Avatar
Spark plug help !!
I just orderd a set of ngk br7es spark plugs and i went to pick them up and the guy said he couldnt get them but he had a set of b7es and they are the same plug just with out the resistor. Would that be fine to run??
Old Jan 22, 2006 | 03:17 PM
bcmind's Avatar
i don't think it works.. .plz don't try...
the label on top the engine specified to use plug with resistor
Old Jan 22, 2006 | 03:19 PM
Jakeg97's Avatar
not sure, but i wouldnt try it
Old Jan 22, 2006 | 03:42 PM
Warrtalon's Avatar
Don't do it. Use BPR7ES/BPR7EIX, BR8ES, or BPR8ESBPR8EIX, but the really you should just use the 7s that I listed. It should only take a day for them to get 4 in stock from another store...
Old Jan 22, 2006 | 03:56 PM
RazorLab's Avatar
Like Wurlytalon said and...
I have been running BPR7ES for a year and about 6 sets in my evo with no problem.
I know people ran the BP7ES in DSMs with no problems but I heard that evos get a little grumpy with them.
BPR7ES's are cheap enough that you can buy a whole box or two at a time so you can always have extras.
Old Jan 22, 2006 | 03:59 PM
Evoryder's Avatar
^ what razor said....cheap yet effective...get a bunch so you don't have to wait the next time
Old Jan 22, 2006 | 06:11 PM
blkdinan's Avatar
I wouldn't even go with any of the 7 series. I installed the BPR7EIX's and when tuning the car with race gas I pumped up the boost and was getting spark blown out. Replaced them with 8's and problem solved. 8's were less than half the price too.
Old Jan 22, 2006 | 06:13 PM
smokedmustang's Avatar
Are my plugs ok? Vishnu recommended BPR8es? or should I go to the 7's. There is a "split" camp on these. please advise, and sorry about the hijacking.
RazorLab's Avatar
What gap did you run?
I have had no problem with 25psi and BPR7ES gapped to .025
Old Jan 22, 2006 | 08:45 PM
blkdinan's Avatar
When I pulled them out they were split .026 and .027 two each. I even have magnacor plug wires so I was certain this was not the problem but guess I was wrong. Mine were iridiums...maybe that had something to do with it?
Old Jan 22, 2006 | 09:21 PM
Warrtalon's Avatar
No, you need BPR8ES or at least BR8ES, because you have a lot of mods. 7s are really for those with 330whp or less...really 300whp or less. I used 7s even on race gas, but had to switch to BR8ES once I started cranking the boost on alky.
I would have used 8s earlier, but my regular 21psi daily driven 300whp mode did not run well even with properly-gapped 8s. It would sputter when building boost below 5k rpm, but would work perfectly above 5k, so I stuck with 7s until just last week...
Old Jan 22, 2006 | 10:13 PM
BURNALL_4's Avatar
OK a NGK Plug #'s are *** backwords from everyone elses a "9" plug like a bpr9es is colder an an "8" plug Like bpr8es. the resistor in the plug is made for radio interference. if you run a snowmobile and use a br9es normally and you cant get them, then the b9es is the exactly the same and because you have no radio you wont have an interference problem. so to answer your question, NO you cannot run a b7es in you evo, it probally wont hurt it but you will not be able to listen to your radio.
Old Jan 22, 2006 | 10:24 PM
Warrtalon's Avatar
This is standard for any plug and is not specific to NGK. Colder ranges have higher numbers. Stock is 7 for the Evo, and to go one range colder, you use an 8.
Old Jan 22, 2006 | 10:49 PM
BURNALL_4's Avatar
i almost agree, this however is NOT standard AC Delco and Champion are the oppsite of NGK the higher the # the Hotter the plug. i do agree with the second part of your statement......i've worked @ Advance Auto for 4 years now, i'm not being an *** or a dick, all im saying is that i've sold a spark plug or 2 and i know what im doing. for instance a 90' chevy 4X4 w/ a 350 engine, in an AC plug takes a CR43TS, to go 1 hotter you use a CR44TS. and no they dont make a CR42TS if its boosted, to go to a colder plug...lol
flyingwangwang
Feb 26, 2012 01:50 PM
memo3
Oct 8, 2008 04:40 PM
Gary@MellonRacing
Oct 1, 2008 06:36 AM
ihatepotholes
54
Mar 5, 2007 10:11 AM
GOKOU
13
Nov 7, 2006 07:39 AM
