Another 20G-9 MONSTER HP chart...
Old Jan 26, 2006 | 02:36 PM
David Buschur's Avatar
Wow. That's about all I can say about what has happened here in the last two days.
Before anyone says it I know, some of you are tired of hearing my numbers and want to see what is going to happen on a more stock EVO. Well, I don't have those numbers yet so you will have to live with more from my own car.
Last time I left off my RS had made 386 whp and 393 ft lbs of torque. This was a race gas with 28 psi of boost.
I wanted to try some new cams in the car. I bought a set of the Revolver's to try out.
We put the cams in yesterday and this morning I threw it on the dyno. It takes some work to get these to idle, they are MUCH more aggressive than the HKS 280's I had. The car sounds like nothing I have ever heard at idle. It's nasty.
To make a long story short. I made about 25 dyno pulls today. All on race gas. The performance is astounding. I let the boost hit 30 psi at about 4000 rpm and then let it fall down from there. I did not attempt to hold 30 psi out to redline although I am sure the car will. I actually let it taper off to about 26 psi.
By the afternoon the car gained 17 whp. Not bad considering what I changed from was already pretty aggressive. Here is the kicker, the car gained 50.9 ft lbs of torque!! Now that is freaking amazing. Granted, I had another 2 psi of boost which will account for some of that but 50 ft lbs is nuts.
These passes were very-very consistent. When I stopped experimenting with some things the torque stayed over 440 ft lbs and the HP was over 400 every pass.
I even set the car up on the rich side and ran it between 11.0 and 11.2:1 and made 401 ft lbs and 437 ft lbs.
I am absolutely amazed. This car is going to be a freaking handful on the street.
Check out this dyno chart:
David Buschur
www.buschurracing.com
Old Jan 26, 2006 | 02:40 PM
Nez136's Avatar
The thing i like most is how early the power comes on...amazing
Old Jan 26, 2006 | 02:41 PM
nutrulz's Avatar
May I be the first to say... HOLY ****
Any one want to by a set of HKS 264 272s?
Old Jan 26, 2006 | 02:42 PM
nils's Avatar
awsome!
I cant wait to get my 20g-9 !!!
n
Old Jan 26, 2006 | 02:44 PM
Nez136,
I should have video taped it today, I forgot. The car is wicked, wicked.
I told Jarrod today if I take him for a ride in the car he'll come back with a neck that's 6" longer from it being pulled back and over the top of the seat from the torque! haha
I can only imagine how this car is going to run. My old DSM with 446 whp and 423 ft lbs on a Dynojet ran 11.05 at 127 mph, those were Dynojet numbers. Come on spring time!!
David Buschur
Old Jan 26, 2006 | 02:47 PM
matt55's Avatar
power curve looks wayyyy better form 5k on
Old Jan 26, 2006 | 02:49 PM
TwStDeVo's Avatar
Wow, this is just plain amazing!!! ive been looking into upgrading my current cams (hks 264s) along with a new turbo, revolver was the cam i was most interested in next to hks, any recommendations for a custom dynoflash car?
Old Jan 26, 2006 | 02:50 PM
NocturnalEVO's Avatar
Those numbers are awesome!!
David, how is this turbo compared to a standard evo 6.5 TME turbo as far as spoolup time? Does the TME still spoolup faster than this one?
Old Jan 26, 2006 | 02:52 PM
C6C6CH3vo's Avatar
Duration can only help a little, it's the lift in the revolver cams that counts. Mr Buschur, if for some reason you ever plan to sell the head from your RS, can I have first dub?
Would this mean a revolver cam setup, paired up with alcohol, will provide me a good reason to keep the VIII and not turn it in for a IX?
Old Jan 26, 2006 | 02:56 PM
matt55's Avatar
David would you think that a stock head(non proted) would see the same gains from the new cams ? Or is this where your stage 3 head really shines ?
Old Jan 26, 2006 | 02:57 PM
Nez136's Avatar
Originally Posted by davidbuschur
Nez136,
David Buschur
Like said in another thread, my 20g-9 is sitting on my table waiting for the install kit...i also called Nick and ordered an o2 housing.....looks like 2 weeks. In the mean time i might have to order one of your alky kits.
Old Jan 26, 2006 | 02:58 PM
EVIL_EVO_VIII's Avatar
Sick!!
Old Jan 26, 2006 | 03:04 PM
evolgrl's Avatar
WoW Dave I was thinking about those cams but you don't stock them my car is the black one with silver wing in great hands !
Old Jan 26, 2006 | 03:09 PM
C6C6CH3vo's Avatar
As long as you let Jarrod drive it (JK), but seriously high 10's sounds reasonable.
What revolver cams did you install?
Old Jan 26, 2006 | 03:13 PM
RazorLab's Avatar
What octane race gas where these pulls done on?
