Another 20G-9 MONSTER HP chart...
Originally Posted by davidbuschur
I am absolutely amazed. This car is going to be a freaking handful on the street.
Check out this dyno chart:
David Buschur
www.buschurracing.com
I bet you can feel that!
Originally Posted by ogvw
I like how its making 100ft lbs more from the beginning of the pull to about 4200rpm
( Sorry, Great job!)
So the Revolver hot tip is almost the same as the smallest Tomei Procam?
Revolver specs
Perhaps you should try the Tomei cams on for size.
This is an excerpt for Z1 Performance http://www.z1auto.com/prodmore.asp?m...ine&prodid=812 site about the Tomei Procams. (Sorry for ripping Adam, but you said it perfectly)
The Procams are for those looking for more top end power, making them a perfect companion for larger turbos such as a GT35, or Greddy T67. These cams feature 260 degrees of duration on the intake and exhaust cam, but steps you up to 11.50mm of lift on both the intake and exhaust cam.
The two newest grinds from Tomei are for those that want the ultimate Evo cams. Featuring your choice of 270 degrees or 280 degrees duration with a massive 11.5mm lift, these cams are not for the shy among us. Got a big turbo that you are looking to maximize the horsepower for? These new Procam grinds are the perfect ticket!
Revolver specs
Originally Posted by matt55
David would you think that a stock head(non proted) would see the same gains from the new cams ? Or is this where your stage 3 head really shines ?
My question is whether you could get the car to idle and drive on the stock ECU without throwing a P0300 code with these cams to get it through OBDII emissions inspections between running the EMS on a normal basis.
Holy crap! I'd like to see what happens when hammer 2nd gear at 4500rpm.
Feb 4th I'll be on your dyno again -- no head work stock bottom end etc.. I do have HKS 264's.. It will be interesting to say the least
Originally Posted by TalonRcR
Did they drop their price? 749 seems awful cheap for what you get: Cams, springs, retainers. Please say it isn't so, if it is true looks like I'll have to plop down 749 tomorrow.
Just to keep it on topic, great job Dave. Now all you need to do is do an alky run. or I can just wait for Nez to gimme a call to help with the install and tune.
