Another 20G-9 MONSTER HP chart...
Old Jan 26, 2006 | 09:12 PM
  #61
timzcat's Avatar
Nice numbers David.
Can't say I am suprised, though. At least now I am not the only to say these cams are crazy.
Old Jan 26, 2006 | 11:08 PM
  #62
mttam510's Avatar
Originally Posted by DynoFlash
I agree and to amplify - when you go agressive on cams - usually valve train life is shortend to some extent - HKS cams are mild enough where you can expect stock like longeviety
With agressive high lift cams you loose out on idle and emissions and valve train life span but pick up on power
There are many design criteria in making any performance product
The most powerful is not always the "best" - the application and intended use is what determines the appropriate parts
You will not have any shortened valve train life with our product. That is yet another reason for the springs and retainers. Springs and retainers really should be used with HKS cams as well to extend valve stem seal life.
In addition to designing a valve spring to match our profile, the profile itself has been calculated to ensure that the rocker to cam lobe interface is "smooth" throughout the duration. You can be sure that we did our homework.
Old Jan 27, 2006 | 04:15 AM
  #63
Zeus's Avatar
I was going there...
Old Jan 27, 2006 | 07:08 AM
  #64
David Buschur's Avatar
evoonyoass,
You tried these cams too? What kind of results did you have with them?
David Buschur
www.buschurracing.com
Old Jan 27, 2006 | 07:37 AM
  #65
Corey's Avatar
Originally Posted by justchil
Holy crap! I'd like to see what happens when hammer 2nd gear at 4500rpm.
Feb 4th I'll be on your dyno again -- no head work stock bottom end etc.. I do have HKS 264's.. It will be interesting to say the least
Just make sure you AT LEAST get some 93 oct. numbers under your belt....PLEASE!!!!! I want this turbo and I'm going frow 264's to 272's so I'd like have a idea of what I'm working with here.
Dave....congrats on the numbers. Everytime you post this stuff I want one more and more.
Old Jan 27, 2006 | 08:25 AM
  #66
Soon 2 B EVIL's Avatar
so ur running the only setup they have the 262/264 dur and 11.4/11.5 lift?
Old Jan 27, 2006 | 09:11 AM
  #67
ogvw's Avatar
correct - that is the set that they are running
Old Jan 27, 2006 | 09:15 AM
  #68
EVOONYOASS's Avatar
Originally Posted by davidbuschur
evoonyoass,
David Buschur
No, but by the looks of things I will be switching. I was referring to the 20G, sorry.
Old Jan 27, 2006 | 09:52 AM
  #69
RKT SHP's Avatar
hey david what if i already have you stage three head with your springs and retainers. if i get this cam(revolver) will i have to replace your springs and retainers or will it work fine with them. because if that is the case all i need are the cams
Old Jan 27, 2006 | 10:36 AM
  #70
EVOlutionary's Avatar
Check out this dyno chart:
David Buschur
I don't know if anyone noticed this or mentioned this, but in addition to the huge TQ increase, it looks like you gained about 60WHP from 6600rpm till you let off. With how flat the HP line is with the Revolvers vs the HKS, it looks like you will continue to gain top end vs. the 280s the further you carry it to redline. Extrapolating to 7500 rpms you should be around 360hp with the revolvers compared to about 280hp with the HKS 280s, an 80 WHP increase!
Do you agree?
EVOlutionary
Old Jan 27, 2006 | 11:40 AM
  #71
rkt,
If you have any of the spring/retainer sets we sell and carry you will be fine with just putting the cams in. I am waiting on pricing on just the cam sets from Revolver
Evolutionary,
There are a few things with the tune that I changed up top so please disregard the big gains in power over about 6,000 rpm. Seems no matter how much I feel I have mastered tuning every ounce of power out of a car there is always something that keeps me awake at night. This time there were some substantial gains with a few idea I tried. These gains had NO effect under 6,000 rpm as I didn't do anything differently there.
David Buschur
Old Jan 27, 2006 | 12:32 PM
  #72
TwStDeVo's Avatar
Amazing looking dyno sheet
do you think you can tune these revolver cams with your flash?
Old Jan 27, 2006 | 01:33 PM
  #73
RKT SHP's Avatar
thanks that is EXACTLY what i wanted to hear
rkt,
Evolutionary,
David Buschur
Old Jan 27, 2006 | 02:44 PM
  #74
Yes, this turbo can be custom tuned with the flash. Al comes here once a month to do tuning. He is coming end of next week.
David Buschur
Old Jan 27, 2006 | 03:51 PM
  #75
TwStDeVo's Avatar
David Buschur
sorry, i should have been more clear. i was asking Al if he thinks he could tune the revolver cams with a flash.
