Another 20G-9 MONSTER HP chart...
Old Jan 31, 2006 | 11:51 AM
  #106
phenem's Avatar
Originally Posted by deadbeatrec
bump for an answer for my ? too
I think from what David has posted before, it does NOT come with the gaskets because it uses the same gaskets the stock 16g would. Here is a picture from his website of what is included in the kit:
My impression is that the oil/coolant lines change and the turbo outlet pipe to the intercooler is changed so he includeds what changes from the EVO8 to EVO9 turbo.
Help at all?
~Zach
Old Jan 31, 2006 | 11:56 AM
  #107
justchil's Avatar
Exactly! Also if you need fast answers just call them.
Old Jan 31, 2006 | 12:00 PM
  #108
phenem's Avatar
Originally Posted by Nez136
What are you talking about, you send them the turbo, they keep the hotside, replace the compressor with the evo9 cover, and install a 20g wheel. What don't you understand about this!?
I understand this perfectly, my quesion is a little more specific to what they are "actually" doing. What about the hotside wheel and the rest of the journal? Are they just switching compressor wheels or the whole center journal of the turbo? If they are just switching out the wheel then what about an abused turbo that is boarderline from having too much shaft play. I send in an almost perfect turbo and someone else sends in a abused one? And this turbo is then upgraded and sold to me or another customer. What happens 10,000 or even 5,000 miles down road and it goes boom? What is Dave going to do about that? Do you guys see where I am coming from?
~Zach
Old Jan 31, 2006 | 12:07 PM
  #109
justchil's Avatar
I see exactly where you are coming from.. that's why I think calling and talking to Dave personally might be a better option. IT keeps these threads from getting junked up and you get your answer.
I know Dave will back up anything he builds.. that would be a non-issues for me.
Old Jan 31, 2006 | 12:08 PM
  #110
nitz's Avatar
i think your point applies to any purchase that requires some type of core exchange. it should be within your rights to ask for your core to be upgraded and returned to you. mind you that this may increase turn around, but at least you don't have to guess whether or not failure was due to an old part. some people even go as far as marking their cores (heads, blocks, turbos etc) before submitting them, so they know when it is returned. i'm sure buschur will accomodate your request.
Old Jan 31, 2006 | 12:21 PM
  #111
phenem's Avatar
OK Guys,
Just got off the phone with Nick from Buschur. He answered my question.
What he said is that the whole journal gets new bearing/compressor wheel and all. He referred to it as a "like a brand new turbo" but using the core as a starting point. So I said what happens 10,000 miles down the road and it goes boom? He said Buschur will stand behind any product if they created the problem then it is fixed no problem. If the turbo was abused (the turbo company researches this) then it is not covered.
Sorry about posting so much crap on here but some people just post to try and prove people wrong or say they don't do their research. Although sometimes that is the case. I was trying to save myself from calling Buschur and bothering them with less important stuff if someone already knew this or already called about the same issue.
Does everyone understand what I have just posted so anyone else wondering what I am get their question answered?
~Zach
Old Jan 31, 2006 | 01:05 PM
  #112
deadbeatrec's Avatar
ok guys i know what the picture shows, but its states that the kit has everything to install the turbo. and i call and pm david so much i feel like a pest, thats y i figured i would ask u guys who have received the instal kits already.
Old Jan 31, 2006 | 01:23 PM
  #113
Karash's Avatar
I would like to see the same test on stock boost just for giggles.
Old Feb 2, 2006 | 04:01 AM
  #114
EVO8LTW's Avatar
Question for Dave Buschur: How much vacuum do see at idle compared to the HKS 280s?
Old Feb 2, 2006 | 08:34 AM
  #115
David Buschur's Avatar
evo8ltw,
Interesting question. I didn't actually look. I did go pull up some datalogs for you though
On the 280's the car had about 8.4" of vacuum. With these Revolvers it had around 6.5".
David Buschur
www.buschurracing.com
Old Feb 2, 2006 | 08:35 AM
  #116
evo8ltw,
You know you made me think. I don't know that we can use those numbers though. I have been messing with the EMS more and more deeply and have found ways to increase the idle vacuum for better idle and leaner AFR's at idle. I know I did this with the HKS 280's in the car but thinking about it now I don't know if I changed that portion of the program when I installed the Revolvers.
David Buschur
Old Feb 2, 2006 | 09:39 AM
  #117
Blue Evo 8's Avatar
Dave on my 280's I'm getting about -14.5 vacuum...
Old Feb 2, 2006 | 09:54 AM
  #118
blue evo8. What are you measuring this on? A boost guage? If so it is not as accurate. I am using the EMS. That is a LOT of vaccum for even stock cams.
David Buschur
Old Feb 2, 2006 | 09:57 AM
  #119
Blue Evo 8's Avatar
David Buschur
I measure this with the HKS EVC 5 EBC's display. i am aware it may not be accurate though.
I also have the AEM EMS on my car but havent plugged into it since I got tuned.
Old Feb 3, 2006 | 02:42 PM
  #120
vanisher's Avatar
Originally Posted by kmcconn9
we need a video clip of the idle dave!!!
+1!
