Revolver Cams + Valvetrain Upgrade Finally Going In
Originally Posted by davidbuschur
This time at the same boost and a little more tuning the car made 761 and 532 ft lbs of torque.
David Buschur
www.buschurracing.com
David Buschur
Originally Posted by Pd1
Thank you for your input, David. I'm glad to hear they're working for some people.
It seems that they may just be too much for us that have less radical setups. The success stories all seem to involve ported heads and built motors etc.
David, I've got a set that I'll sell you cheap if you want them.
Originally Posted by 1StockEvo
As stated earlier in this thread my car is making great power and only on my base tune running the Revolver cams on 91 petrol. My engine is neither built nor do I have a ported head so that excuse about the only success stories being from people with ported heads and built motors should be ruled out. I have to say my set up is not radical at all.
I assume you've made some gain over the stock cams with your car, which is encouraging to those considering these cams on a stock head.
i've calibrated the cams on stock ecu (EcuTeK), Motec M800 OEM with stock Karmann Vortex, Several with Autronic SMC speed density and AEM EMS speed density with no issues... stock turbo, bigger turbo, stock head, big valve head, 2.3L, 2L whatever... granted there are some tricks to a good idle with a factory ECU and flash, but it all works out the same...
i just don't understand why these cams are such a struggle for some people
It's hard to see that you're making great power, honestly. I have no idea what kind of power your car was making on stock cams
and I don't see a horsepower figure on your graph. I see a torque line that peaks about 290 lb/ft, but that's about it. I don't know how the HP line relates to the torque markings on the left.
Also, keep in mind that you have a larger turbo (compared to mine) as well.
I guarentee that my engine will outlast yours by just looking at your AFR chart. Man your car must have been detonating and most likely it was probablly audible did you hear anything or pick up anything with your DSMLINK?
Originally Posted by atlvalet
I think Pd1 mentioned that the wideband wasn't working properly. His datalogs show good AFR's IIRC.
awhile ago I posted saying there was some problem with the Revolver install on my car. Some one wanted to know what it was.
The shop told me one of my coil-plug assemblies had gotten dirty or was loose. so likely not relevent.
Yes, all the cars I have tuned with the Revolvers have had the AEM EMS in them.
David Buschur
David Buschur
I do know that the pcv valve gets noisey on the evo when the idle gets rough and dips. I installed the big crowers in a friends car and is seemed like when car started to idle rough and the vaccum dropped the pcv valve would rattle like crazy. Just a thought.
That's correct. My EMS' estimated AFR (which uses the narrowband O2 sensor and a few other factors) as well as my AEM wideband sensor are in agreement that the TT DynoJet wideband was not reporting accurately. My AFRs for all of the runs were between 11:1 and 11.5:1 at full boost. The knock sensor does appear to be working properly, and is being properly monitored by DSMLink. This is evidenced by the fact that I did see some knock, and was able to tune it out by retarding timing or adjusting mixture.
l8r)
Originally Posted by Ludikraut
Just out of curiosity, when was the last time you calibrated your wideband sensor, where is it installed, and which direction is it facing (i.e. where does it protrude into the tail pipe, top, bottom, side)?
l8r)
l8r)
The WBO2 is installed in my resonated test pipe. With regard to its orientation, if you're standing under the car and looking forward at the back of the test pipe, the sensor sits at approximately 4 o'clock (if 12 o'clock is on top, and 6 o'clock is on bottom).
There is a 0-5V analog output wire coming out of the gauge that is then fed directly into my ECU for logging. The values displayed on the gauge are exactly the same values that are captured in the data log via my EMS. I validated this upon installing the sensor.
