p300 after clutch install
Old Jan 30, 2006 | 03:00 PM
Mark T's Avatar
I sent my tranny and transfer case to TRE for a rebuild and ralliart diff. I also had a exedy organic clutch and prostreet 10.5 lb. flywheel installed at the same time. My car had 44,000 miles at that time and never threw a cel. I also have a Works p2 etc. for 30,000 miles with flawless operation. I do notice much more clutch decel chatter now and I'm wondering if this is a driveline harmonics issue?
Old Jan 30, 2006 | 03:04 PM
SEEYA's Avatar
welcome to the P0300 club, you will soon be inaugurated into the platinum level of membership with copious amounts of frustration benefits...
Old Jan 30, 2006 | 10:28 PM
G20's Avatar
G20
Now! That scared the sh*t out of me since I'm planning to rebuild my tranny and t-case as well. How do you like the new tranny?
Old Jan 31, 2006 | 07:26 AM
dryad001's Avatar
From what I have heard there is a certain "tuner" out there, not on these boards that is trying to rid the ecu of the P0300 altogether. I'll call him later and let you all know what I find out.
Old Jan 31, 2006 | 07:33 AM
dbdude's Avatar
Im intimidated by that code curse. Im crossing my fingers i dont get it when my cams are installed and al flashes my car.
Old Jan 31, 2006 | 08:03 AM
itzwolf's Avatar
I got it on random. I lowered my spark plug gap and I haven't seen it since. May or may not work for you, but always worth a try.
I will never have that problem again however as I recently switched to an AEM EMS.
Old Jan 31, 2006 | 02:44 PM
Mark T's Avatar
I really like the TRE related work, in particular the limited slip front diff. My plugs are gapped at .025 which I believe is the most recommended setting.
Old Feb 3, 2006 | 03:03 PM
Mark T's Avatar
Just wanted to know if anyone with a TRE rebuilt tranny has experienced an increase in drivetrain noise and then a p300 code?
MikeB@FFTEC
36
Nov 4, 2019 05:23 PM
ohYouEvo
Aug 28, 2016 10:58 AM
Gonzo0991
24
Mar 17, 2012 06:57 PM
jude
13
Mar 19, 2006 10:58 PM
03EvoVIII
Mid-Atlantic Region
Sep 19, 2005 11:50 AM
