EVO8....crank walk??
Old Apr 2, 2003 | 01:45 AM
TrippinFlip214's Avatar
Originally posted by Hitman
There was no found rhyme or reason behind this. There were many theories but none were found to hold water fully.
This is what im worried about. How can you fix/prevent a problem without knowing the root cause.
What exactly did improve on the EVO8 engine? Was the previous EVO's have the same configuration/specs as the EVO8? I dont know much about EVO's but did any of the previous evo had 5-speed?
From what i understand, crankwalk happens only to manual transmission. correct me if im wrong.
Old Apr 2, 2003 | 05:55 AM
leonard_shelby's Avatar
From what little I know, being "crank walk" the tranny wouldn't seem to matter.
Old Apr 2, 2003 | 03:08 PM
CornerHard's Avatar
Crankwalk has happened on some automatics, but it's much less common. As I understand it, it's because the AT doesn't put a big lateral load on the crank bearings like a clutch does when you press it down.
poonpower
Nov 6, 2015 09:06 AM
O0oDC
26
Sep 3, 2015 05:46 PM
_PT
12
Dec 3, 2014 11:29 AM
ptm5070
Jun 28, 2014 05:34 AM
T-55
31
Apr 27, 2008 10:28 AM
