rev drop problem
Old Feb 14, 2006 | 06:14 AM
xtnct's Avatar
Thanks TTP, but clutching in did not work on my 06 (at least the time I tried it). Accell in 3rd to 5K, still in gear, clutch in, rpm's come down really slow till 3k rpm (about 5 secs or longer), after that it drops fast (ie, normally) to 1K rpm.
Are you saying I need to clutch in at 5K, and then immediatly clutch out and then rpm's will drop normally?
Old Feb 14, 2006 | 06:15 AM
xtnct's Avatar
Originally Posted by bigric09
Blow Off Valve ?
No, STOCK.
Old Feb 14, 2006 | 07:36 AM
TTP Engineering's Avatar
Clutch in 2x
It is a clutch switch you are trying to engage that will trigger the rpms to come down.
Old Feb 20, 2006 | 01:24 PM
meek61480's Avatar
i get a different reving problem that is driving me up the wall. when i push the throttle half way down, the turbo acts like i am flooring it and fully boosts. when i let off and push the clutch in the rpm's still climb. ALL THE TIME. if anyone has a cure PLEASE PM ME.
12WWGSR91
Jul 28, 2014 09:13 PM
jj_008
10
Jul 11, 2010 10:46 AM
illmatic165
15
Feb 22, 2009 09:37 AM
Malik_EvoIX
11
Aug 19, 2008 10:58 AM
TrinaBabe
Feb 28, 2005 04:18 PM
