Excessive GAS Consumption...
Old Feb 6, 2006 | 01:29 PM
projekt_shocker's Avatar
Isn't kinda too much to run out a full tank of gas in less than 3-4 days?!?!?!
I didnt drive like a maniac either... I drove around town and that was it... I also noticed that my car has a check engine light, went over to autozone to pull up the codes and they told me it was code p0134... something concerning with the bank 1 o2 sensor... could that be the problem to my gas guzzlin evo??
Well, I'm getting the sensor fixed by mitsubishi at no charge. I just hope that should remedy my issue.
Old Feb 6, 2006 | 01:33 PM
IDRINKV8's Avatar
are you stock?
Old Feb 6, 2006 | 01:35 PM
TxEvo8's Avatar
That all depends on how many limes you drive in those days. What is you mpg? How many miles are you getting on a tank?
Old Feb 6, 2006 | 01:38 PM
Ted B's Avatar
The ECU is telling you that there is a problem with that sensor (or the connection to it). As a result, the ECU cannot go into closed loop mode, and your fuel economy will be significantly reduced.
Verify that the wires aren't burned and there is a good connection. If there are no issues there, the sensor may be toast.
Old Feb 6, 2006 | 03:24 PM
DaWorstPlaya's Avatar
+1 ... its sensing there is something wrong with your emissions system and thus the car is running in rich mode (more fuel consumption) as to protect the engine ...
Old Feb 6, 2006 | 03:35 PM
exactly, the car is runnin rich... everytime i step out of the car after driving home from work all i smell is gas from the exhaust...
no the car isnt modded.. well all i have is just a intake adapter that hooks up with the stock intake hose... but no down pipe exhaust... and that stuff...
oh yes i also have a hks turbo timer in the car too.
Old Feb 6, 2006 | 03:40 PM
besides... the car will go back to the dealership to get that o2 replaced for free... so im not *****in.. haha.
Old Feb 7, 2006 | 11:07 PM
Takahashi's Avatar
youre lucky that this problem was solved so easily for you... I'm refueling every other day... Even if I do drive my car like I stole it, its adding up to be too much...
Old Feb 7, 2006 | 11:45 PM
mooreboost's Avatar
Clean out your filter really well.
Mine was filthy and it was effecting my gas mileage incredibly.
Old Feb 8, 2006 | 06:35 PM
MiDkNiGhT EvO's Avatar
Hi guys i just put a megan racing downpipe, ultimate racing high flow cat and then a megan racing exhaust it hooked up great but a week later the cel came on n it was couse of o2 problem... so im facing the same problem as the guy who started this thread... do i need a new o2 sensor or just a perrin check engine simulator...? I just want the check engine light off... My gas mileage to go back up and my car to run right again what do i do thanks?
Old Feb 9, 2006 | 07:57 AM
You can use either the perrin check engine emulator or the sparkplug anti-fouler trick to get rid of the CEL...
Old Mar 14, 2007 | 01:25 PM
1 YEAR LATER...
my car have this code back up again...
is there a way i can just put that o2 cheat in my o2 housing? i already ordered a new sensor, but wanted to see if i added in that anti-fouler/cheat in the o2 housing see if that would work out.
let me know thanks.
Old Mar 14, 2007 | 01:33 PM
spdracerut's Avatar
1 YEAR LATER...
let me know thanks.
No...... the purpose of the O2 sensor is to let the ECU know what A/F it's running. 'Closed loop' operation means the ecu checks the A/F ratio using the O2 sensor, and then makes adjustments to try to hit the ideal A/F (14.7 at light loads). 'Open loop' means it ignores the O2 sensor and makes no adjustments.
The fuel map for 'Open loop' operation is excessively rich to protect the motor from detonation.
So from the sounds of it, the O2 sensor is jacked, the ecu is running in open loop all the time, and burning lots of gas.
MitsuSkot
Apr 9, 2016 05:39 PM
spyder526
Jul 28, 2012 07:37 PM
Antlane90
Feb 24, 2012 08:30 PM
Y.O.EVO8
Mar 30, 2010 03:40 PM
kanyonkid
14
May 29, 2008 09:21 PM
