10.5 hotside ?
Old Feb 16, 2006 | 10:19 PM
dave9172's Avatar
10.5 hotside ?
i am interseted in adding a few extra hp. i was looking into the 10.5 hotside. i noticed on gruppe-s they had a single and double port, the one being about 30.00 more than the other, which one should i get. what is the difference? also how much of a pain is it to install(how many labor hrs), how much hp can i expect?? thanks.
Old Feb 16, 2006 | 10:25 PM
bluebanana23's Avatar
15hp if tuned correctly but install is a pain in the *** if you ask me. There is a tutorial on here and please ask the mods to move this to engine/turbo section.
Old Feb 16, 2006 | 10:34 PM
dave9172's Avatar
ok thanks, anything w/ the difference between the single vs. double port, gruppe-s is the only one ive seen w/ both??
Old Feb 16, 2006 | 10:41 PM
AtO-MiX's Avatar
the single port is the new version of the 10.5....the dual flapper is the same like on the 9.8. The single is supposed to have a smoother flow/holds boost better..its an improvment over the dual flapper design. I plan on getthing the 10.5 single port and MR 02 housing pretty soon myself
Old Feb 16, 2006 | 10:48 PM
dave9172's Avatar
nice thanks, it sounds like the single is worth the 30 extra $$ icant wait, i wanna get 10.5 hotside, 264/264 cams(havent decided which kind), licp and tune.
Old Feb 16, 2006 | 10:55 PM
AtO-MiX's Avatar
yeah i was going to get some buddyclub spec II cams 264/272... but decided to go with o2 housing and 10.5 and flash...my goal has always been 300-310whp and with that set up i will be there.Cams was something i thought about at the last min...i mean they are awesome...but i really plan on stop modding once i hit my goal...and when u get cams u got to get tuned which is another 300+ on top of the the 400/500 for cams just dont feel like spending anymore.
Old Feb 16, 2006 | 10:59 PM
dave9172's Avatar
i would think you would be close to that already w/ your existing mods, what octane gas do you use.
Old Feb 16, 2006 | 11:02 PM
AtO-MiX's Avatar
93 i am pretty close i am not quite there...there are no dynos in san antonio at least that i know of ...but some really smart ppl on this site (WT and others) and a couple of ppl who work on my car with me say i should be around 280whp right now...the flash will def get me to 300whp and the o2 housing and 10.5 will add who knows.
Old Feb 16, 2006 | 11:04 PM
dave9172's Avatar
goodluck, thanks for the help!
Old Feb 17, 2006 | 01:45 AM
FlyNavy's Avatar
I've gathered from those here smarter than me that the single/dual flapper issue is pretty much negated if you plan to upgrade your WG actuater. (ie higher boost applications with alky 23-26psi) Otherwise the fact that I'm about to install an "old tech" dual would drive me nuts.
evil mechanic
18
Sep 4, 2006 10:17 AM
Gruppe-S
14
Aug 22, 2006 09:25 PM
Gruppe-S
Mar 22, 2006 06:52 PM
flo2877
Jan 8, 2006 11:09 AM
4TUN8
Oct 21, 2005 03:21 PM
