Best GT35R kit for the money
Originally Posted by Blue Evo 8
Is there much diff between the FP 3052 vs the FP 3065??
Yeah I know....search lol.....
Another thing, i was just reading this thread and started researching some of the kits that people listed mainly the Shearer, AMS, Buschur, and Full-Race. One of the reasons the Full-Race kit is so much more expensive is the fact that it includes a large intercooler with it, it is 24x11x3, and by comparison AMS's race intercooler is 22x12.4x4, and buschurs is 24x13x4, so that sorta offsets the cost of buying a new one. AMS wants almost $1700 for the race intercooler with piping, Buschurs is $700 without, and Full-Race comes with the piping. Now i don't know the flow rates vs. pressure drop with all of these but the sizes seem comparable, also i wonder what intake manifold alot of these cars are using, i know AMS and Buschur make their own but are they using their intake manifold when making this amount of power and track times?
AMS - 22 X 12.4 X 4 = 1091 cu. in.
Bus - 24 X 13 X 4 = 1248 cu. in.
So which did you say was larger?
Originally Posted by Mercenary3
I was under the impression that the 3052 was a 3076 turbo with the FP exhaust housing on it instead of the garrett housing. And the 3065 was a GT30R with a GT35R compressor wheel on it instead of the 3076/52lb compressor and also a FP exhaust housing. Someone let me know if im wrong.
Whoops Ted B my bad i didn't take the time to calculate the acual cu. in. of the intercoolers sorry about that. But good info none the less i'll have to remember that when i build mine, looks like the bushur is the way to go.
True, size is but one of several factors that must be considered when evaluating an IC.
My point is simply that the physical capacity of an IC is calculated in 3 dimensions, not 2.
Originally Posted by mchuang
I am kind of curious as to why a slim fan is needed if the fan is between the radiator and intercooler
the ideal way to size an intercooler is to calculate the required mass flow rate before the core sees a real pressure drop, and use that to set how much power the car is going to make. (ted b, im sure you already knew that)
I usually agree with Full Race, on this intercooler stuff though the theories that get thrown around I could care less about. Too much time building, testing and measuring. There isn't a way to physically put a big enough intercooler in an EVO without cutting the hell out of it, if you plan to stick with a thin 3" core.
In this case thicker is better.
The EVO also has an excpetional cooling system even stock and overheating I have yet to see in any conditions.
David Buschur
www.buschurracing.com
David Buschur
Originally Posted by davidbuschur
It's been an interesting month.
The GT35r's are getting rediculous. I can't tell at this point if it is our kit change that did it or the tuning on the cars I have done but the GT35R is turning into quite a streetable turbo. I use to hate the lag of them but the last few we put on were very quick to spool.
David Buschur
David Buschur
