Best GT35R kit for the money
Originally Posted by FahKen Evo!
What change did you offere to the 35R to make a better spool?
Originally Posted by Full-Race Geoff
There is not much you can do to the turbo itself to improve spool. However, if the manifold or downpipe had a design change to get better flow in and out of the turbo, that can improve spool. Otherwise the only way to improve spool is to increase displacement
. So the Buschur unit should offer quicker spoolup then a tubular manifold setup?
You can also change turbine housings to a different A/R to make it spool faster, changing the A/R on the compressor side will also help spool up. Then there is the matter of boost controllers, they play a huge role in how fast the turbo spools along with the spring pressure used in the wastegate.
David Buschur
www.buschurracing.com
David Buschur
David Buschur
David Buschur
The spring pressure varies, normally we ship them with 1 bar springs in them. I don't know if Tial makes a 21 psi spring, if so then yes. The halman would work fine.
David Buschur
David Buschur
Sevi_EvoX
Sep 18, 2008 07:06 PM
