MBC off? Is there a point?
Old Feb 24, 2006 | 05:09 AM
Assassin's Avatar
Ok I have a TurboSmart Single stage MBC on my Evo with the cabin toggle switch. Is there really a point to turning the MBC off? I mean considering the fact that if I do, the car will run off the wastegate limited pressure of 11psi which is WAY under stock. The only "point" I can see to that is POSSIBLY saving gas maybe? Assuming that the less air incoming, the less fuel the car will need to run. Or am I wrong? I figured that maybe on long trips, I'd wanna turn the MBC off to save gas.
Side note: Flaming won't be responded to so don't waste your keystrokes.
Old Feb 24, 2006 | 05:58 AM
Assassin's Avatar
Nobody?
Old Feb 24, 2006 | 06:09 AM
Warrtalon's Avatar
You're right. There's no reason to have it. I don't know why people bother wasting money on that stuff.
Old Feb 24, 2006 | 06:12 AM
Assassin's Avatar
Wasting money on the cabin control? Yeah I agree. I shoulda thought about that before I bought it. Coulda saved me 70 bucks.
Old Feb 24, 2006 | 06:15 AM
Warrtalon's Avatar
No, cabin control is fine. I'm talking about those weird Turbosmarts with the switches.
Old Feb 24, 2006 | 06:18 AM
Assassin's Avatar
Oh. I take it the cabin control is being able to adjust the boost without gettin out of the car. Ah dammit. Now I wanna unhook the switch altogether. It being there pisses me off.
Old Feb 24, 2006 | 12:13 PM
Fourdoor's Avatar
If you live in an area with very slick driving conditions having a low boost setting works as a form of traction control. I think you are a bit too far south to worry about that though.
Now, if this setup has seperate lines that bypass the boost controler to give you wastegate spring pressure, then you can put a manual boost controler in that bypass lineup and adjust it up to higher than your normal boost level for use with race gas, or as a high boost setting with an alcohol injection kit.
Keith
Old Feb 24, 2006 | 01:17 PM
fsugatorbait's Avatar
Valet mode.
Old Feb 25, 2006 | 07:56 AM
platinumspecv's Avatar
Originally Posted by fsugatorbait
Valet mode.
+1
chaotichoax
Apr 12, 2020 11:55 PM
Arlo
30
Nov 13, 2016 12:18 PM
Mellon Racing
Feb 17, 2016 01:22 PM
prowakeskater
Apr 22, 2011 09:47 AM
svt_lightning01
Mar 31, 2011 01:08 PM
