Buschur Mbc problem
Old Feb 28, 2006 | 05:49 PM
4-BNGR's Avatar
Buschur Mbc problem
I've turned it way down - almost to the point of having the knob come off. But I'm still boosting 25psi plus. Yes it's properly installed and I have the 6.5 RS TME turbo (non hybrid) and VDO 30/25 Boost gague... Anyone. Do I need to take the mbc apart, clean it, etc... Thanks
Old Feb 28, 2006 | 05:56 PM
Warrtalon's Avatar
Sounds like a hose is pinched or the wastegate is stuck. Check to make sure no hoses or pinched and that the WGA nipple isn't bent. Also, switch in someone else's MBC just as a troubleshooting step to verify if it's the MBC itself or not.
Old Feb 28, 2006 | 06:00 PM
4-BNGR's Avatar
It's this one....
Old Feb 28, 2006 | 06:05 PM
use2vtec's Avatar
If I remember right thats a ball and spring type. Try unscrewing it all the way then take out the ball and spring and lube them up.
To eliminate the boost controller just disconnect it and run straight off of wastegate pressure. If you still have a issue then its in the wastegate or a vacum line. Goodluck
4-BNGR's Avatar
My guess is that the wga is stuck. Can't I fix this by shortening the wg arm. Hoses and nip look ok. Damnit
Old Feb 28, 2006 | 06:07 PM
4-BNGR's Avatar
What should I lube it with? Thanks...
Old Feb 28, 2006 | 06:11 PM
use2vtec's Avatar
I would think a very very light coat of oil will do the trick.
Old Feb 28, 2006 | 06:41 PM
fsugatorbait's Avatar
Loop the wastegate and and turbo nipple together to test the wastegate pressure or switch out the MBC. You need to start taking components out of the equation if the visual check looks good.
AdamWest
May 3, 2011 08:15 PM
PEARLEVOIXMR
30
May 16, 2007 06:24 PM
Rcebowl
21
Sep 14, 2005 11:07 AM
VIIImylunch
Aug 18, 2005 12:09 PM
lightweight
Dec 20, 2004 06:18 PM
