BLOWN motor Part 2 (upper end pics)
Old Mar 9, 2006 | 04:31 PM
Stew's Avatar
Well the head has been ripped off of the block, no resolution yet but the District Rep sent his pictures to Mitsu in
California and I should find out sometime tomorrow if the warranty is holding I guess. I was able to get down
to the dealership and take photos myself, here is what we are looking at.
For those of you not familiar, my first thread is here: https://www.evolutionm.net/forums/sh...1&page=1&pp=15
Cylinders
Cylinder walls
Cylinder #1 wall
Cylinder #2 wall
Cylinder #3 wall
Piston #1
Piston #2
Piston #3
Piston #4
Cylinderl #1 valves
Cylinder #2 valves
Cylinder #3 valves
Cylinder #4 valves
Plugs #1 & #2
..Piston #1 took the most beating, probably because it was the first rod to let go. None of the pistons show any
major signs of detonation (as far as I can tell), nor do the plugs, which is good. I'm not sure how exactly the wall
scoring came about though, wether it was a matter of the crank being shifted causing a messed up stroke or
what. Wall scoring is front and back of the cylinders, not side to side.
Old Mar 9, 2006 | 04:33 PM
evo637's Avatar
Are they basically going to replace your whole motor
Old Mar 9, 2006 | 04:38 PM
Stew's Avatar
Thats what the tear down was concerning, and only if they decide this is a warranty job. It would require an entire long block and transmission. See other thread.
A418t81's Avatar
Looks pretty much detonation-free to me as well. Hope Mitsu comes through for you.
Old Mar 9, 2006 | 04:40 PM
VW4life's Avatar
Ouch!
Old Mar 9, 2006 | 04:43 PM
LimPShoT's Avatar
My Evo is thinking of your Evo and hopes ya get this covered under warranty
Old Mar 9, 2006 | 04:50 PM
Greg K's Avatar
you were a little bit lean looking at the piston tops, but not too bad. I see no obvious signs of knock either. Hopefully Mitsubishi will do right by you. From my experience as an engine builder/racer, I would say the flash and modifications likely had no effect on the damage.
The only thing that they could probably get you on is if you had the factory rev limiter removed and they claim that the rod bolts were stretched by over-reving the engine (whether you did or not). Good luck man.
Old Mar 9, 2006 | 04:55 PM
Saikou_kun's Avatar
How much should it normally cost to fix this if it isn't under warranty ? I am asking for a friend... not for me
Old Mar 9, 2006 | 04:59 PM
Greg K's Avatar
with labor including the valves and a valve job I would estimate approx 6-8K. The turbo should probably be replace too because there was a lot of metal bits that went out through the exhaust valves and throught the hotside of the turbo when that popped.
Old Mar 9, 2006 | 05:00 PM
Ted B's Avatar
That's in the plane of crank rotation, which indicates very heavy side loading, friction, heat, etc. Those piston skirts are undoubtedly ugly as well.
Old Mar 9, 2006 | 05:03 PM
EVO8LTW's Avatar
Do you have an understanding of whether they are going to charge you for the teardown in the event that it's not covered? I'd be worried about being told it's not covered and then getting a big bill for the teardown on top of that.
Old Mar 9, 2006 | 05:13 PM
jasonc32amg's Avatar
I'm curious why they would cover it with your mods????
Old Mar 9, 2006 | 05:26 PM
RazorLab's Avatar
I dunno, how can that motor get all that damage - balance shaft blown through the block, rods ripping through the oil pan, and broken valves , not to mention the torque it would take to crack your bellhousing while just cruising along on the street in 5th gear at low rpms?
Are you triple dog sure with a cherry on top you didn't over-rev the hell out of that motor?
Although I can't imagine an over-rev would cause that much damage. I major bottom end seize could probably though.
Very interesting.
Old Mar 9, 2006 | 05:36 PM
Greg K's Avatar
if you read the previous thread a major bottom end sieze is exactly what happened.
Old Mar 9, 2006 | 05:47 PM
RazorLab's Avatar
I stopped reading the other thread when people suggested it was because he used a different oil.
I could see it doing that much damage if the motor seized in the upper RPM's but cruising rpms?
