BLOWN Motor Part 3 (DECISION)
Originally Posted by PVD04
I think you misread the post you were responding too. Raising fuel pressure has nothing to do with an OIL pump failure. If the oil pump failed, then this is Mitsu's responsibility, regardless of other mods.
-Paul
-Paul
I feel for you Stew. I was/am in the same boat and I am paying out of pocket for my rebuild. I took a different approach though to the situation.
I have an Evo. I took said Evo to the track multiple times. I also increased power to said Evo by ~50hp. Mitsu didn't build me a racecar, they built a good roadcar that I treated as a racecar. By definition I voided my warrantee by not using the car for its intended purpose (i.e. a roadcar with 276hp). At no point in time did I ever think that Mitsu would cover my repairs due to the fact stated above.
I played and now I am paying. I will continue to play and pay because that is my responsibility, not Mitsubishi's.
I am about 10k deep in rebuilding my car and it will be a blast when I get it back.
2.3l stroker $3200
misc parts $1600 (gasket kit, water pump, oil cooler etc.)
cams $300 (used)
Race FMIC $700
UTEC $800
Labor $2100
valve springs/retainers/valves $800
Head porting and cleaning $400
2.3l stroker $3200
cams $300 (used)
Race FMIC $700
UTEC $800
Labor $2100
2.3l stroker $3200
cams $300 (used)
Race FMIC $700
UTEC $800
Labor $2100
2.3l stroker $3200
cams $300 (used)
Race FMIC $700
UTEC $800
Labor $2100
Originally Posted by Stew
Dont expect me to EVER be asking for hand-outs.
You were not contacted before anything here because your flash did NOT have anything to do with the motor problem, as shown by the tear down. I did not feel the need to call Tien either. etc.
Running without a fuel pump was not the best idea, and I was aware of that. I hope you're not pointing blame here. Does it look to you like a lean condition caused serious detonation, enough to spin a bearing? You may PM me with that answer if you'd like.
While I respect you for not asking for hand outs, i do have a lot of resources to help a situation of this nature and I wiosh you had called me so i could have tried to use some of my connections to assit you before your warranty was voided
My statement was not directed to you in particular but rather as a suggestion for anyone else who may find themselves in this situation. Also, given the comment by Vishnu supported IE and your probably joking response I felt a direct resonse was in order.
I am hoping that people who may utilize my products would contact me to at least run the situation by me before they take the car down to the
dealer for a warranty voiding nightmare.
Well, I'm bringing my opinions around from the vortex again. I don't claim to know much about Evos, but:
- I find it hilarious that people who can't spell the word "warranty" correctly are trying to argue whether or not Stew's should have been voided by Mitsu.
- There are no visible signs of detonation in Stew's photos, and as far as I know mail in ECU flashes do not weaken rod bolts as long as the car is driven properly and not over-revved.
- Regardless of the aftermarket parts, Mitsu still has to prove that they led to the engine failure. It's not as simple as, "He got a reflash, so now the warranty is void."
- People on here are constantly flaming at each other and going off-topic seemingly unprovoked.
Basically, saying that Stew's modifications to his car caused this catastrophic engine failure is on par with VWs warranty denials saying that chipping a car causes the timing belt to break with only 15K miles on the clock. I could care less whether or not
honors the warranty, but I do honestly believe that they need to PROVE that aftermarket modifications led to the engine failure.
I have a friend who had his stock Evo spin a rod bearing on the dyno doing a basline run, and Mitsu denied his warranty because his car was on a dyno. He is still trying to fight them legally over the matter. I think that the amount of trouble that Mistubishi goes through to void warranties (browsing enthusiast forums) is ridiculous.
I understand that this is an important thread for all of you on here, but I doubt that anybody whose Evo just ate it this badly wants to deal with the crap that some of you are posting on here.
honors the warranty, but I do honestly believe that they need to PROVE that aftermarket modifications led to the engine failure.I have a friend who had his stock Evo spin a rod bearing on the dyno doing a basline run, and Mitsu denied his warranty because his car was on a dyno. He is still trying to fight them legally over the matter. I think that the amount of trouble that Mistubishi goes through to void warranties (browsing enthusiast forums) is ridiculous.
Originally Posted by IE Evo
In other words Stew, u pissed Big Al off by making your mishap a public spectacle. U should of kept it on the Down Low and u might of been treated better and other Evo Enthusiasts would be more apt to think Al has a perfect tuning record. Also passively stated, if there were less monetary damage to your car, Al would likely help u and assume some of the responsiblity, if premise number one had been adhered to. Even for Big Al 10,000-15,000 grand is too much Dinero and he needs that money for the built motors he will need for the next race season.
IMO All tuners make mistakes and some cars are not Base Flash compliant. Should Al help u in this case? Probably not but I feel he should start assuming a lil responsibility for a tune that displayed a dangerous AF/R above 6000 rpm. Many have had flashes from other tuners with similar mods with the stock fuel pump and AF/R were still in the safe range. Car makes no power it is a "boost leak issue" and now if a car runs lean on a base flash it is a "fuel pump issue". Only if he would of flashed u the first time with a base flash that was stock fuel pump compliant.
especially in your role as #1 Vishnu ball hanger
Just for the record - I have never had to repair anyone's motor on the down low or otherwise to date
To be very honest with you the reliability record of the mail in flashed cars has really come as a suprize to me. This applies to not just mine buty the other comapnies as well.
When you factor in all the mechanical installations and possible failures of parts such as MBC installs, fuel pump installs, cams - abusive driving, racing lack of oil changes and all the other insane BS that the motoring public puts the cars through I am shocked that basically the mail in flashes have had a reliability record just as safe as stock and any cases of failures are few and far between.
The bottom line is that the stock ECU itself contains a very effective self preservation system which makes it almost hard to blow up one of these cars with bad tuning alone.
Properly set up a reflash is very reliable as shown by the thousands of people out there with them.
As for me backing up my product
If there is a faliure I would want to examine the car and my tune and you and others can count on me doing the right thing to correct the situation IF I have made any mistake - which is possible.
Finally - I find your repeated reference to allegded "lean" or dangerous tuning in my product to be quite underhanded and ill advised.
It is funny as the #1 Vishnu ball hanger you take every opportunity to bash and undermine other vendors - when in fact your own Vishnu has been documented to intentionally tune cars - even on 91 octane - to a 12.0 /1 a/f in the mid range of the power band.
Also - it is documented that Vishnu has had more rod failures that Dyno Flash tuned cars .
Thanks for your posionous jabs
Originally Posted by shivaswrath
they void for dyno runs?
are you serious?
oh crap,
if my warranty is voided, then hell, I"m going ***** to the wall now!
are you serious?
oh crap,
Wasn't
also the company that voided warranties on engine failures after they found out that owners had been autocrossing?I just don't understand how some of the people working for them can sleep at night.
So when a Car mag. like motortrend did the comaprison dyno test Evo vs. the STI, they VOIDED the powertrain warranty of the Evo by performing the dyno test?
Wonder if the testers were aware of that..............lol
No wonder Mitsubishi of America is in trouble........
2.3l stroker $3200
cams $300 (used)
Race FMIC $700
UTEC $800
Labor $2100
2.3l stroker $3200
cams $300 (used)
Race FMIC $700
UTEC $800
Labor $2100
Originally Posted by anjapower
Fight with Mitsu to the bitter end. You got a defective motor and they need to fix it. Get a lawyer if it comes down to it, it will be a lot less than 15k, that's for sure.
they can't void your warranty just because of a dyno run or for aftermarket parts. They have to prove that it caused the failure. Get a lawyer, a bunch of mechanics to discredit mitsus claim , and follow the steps above and you might have a chance. They do void the warrantys first then you have to fight it like stated above but if you win then the sweet thrill of victory will be that much sweeter.
i don't get what is so funny about that... for some of us, english is not our main language andd i find it funny that you would come all the way from vortex just to make fun of people spelling skills. if i don't know how to spell, does that mean that i ddon't know what is right or wrong?
i am glad you know it and i know it too but that does not mean that mitsu knows it. for them, he voided the warrenty (just for you andd just on the engine) the minute he changed the ecu settings.
that might be true but that should be easy enough since they KNOW that he had his ecu tuned, they KNOW that the car was on the dyno under stressful conditions etc..
again, i am talkinging in general and not about Stew's car in specific. even if they can not prove that the ecu tuning caused the engine to blow, all they havee to do is show that he used the car for racing or other stuff that they don't want you to do.
if they can void warrenties for people that auto-x, you can bet your *** that they will have no problem voiding his warrenty...
we know and we are trying to deal with it.
well, what i or you think has nothing to do with what they acttually have to do or what they will do. all i know is that if people decide to mod their cars, they should be ready for stuff like this.
i don't. put yourself in their shoes for a few seconds. do you have any idea how many stupid kids bought this car, raced the crap out of it and blew it up and than went in for the warrenty work? trust me, you would do the exact thing if you were them. i havee been on this board for quite some time and take my word for it, people scamed mitsu more times than mitsu voided warrenties...
well, we all wish the guy good luck and i really do hope that he gets out of it. we are all allowed to speak our minds as long as we do it in a respectful manner...
honors the warranty, but I do honestly believe that they need to PROVE that aftermarket modifications led to the engine failure.well, what i or you think has nothing to do with what they acttually have to do or what they will do. all i know is that if people decide to mod their cars, they should be ready for stuff like this.
