Upgrade...Whats next...
Old Mar 14, 2006 | 02:11 PM
TurboMR's Avatar
I have the 3' Invidia DP and the 3' Invidia G200 exhaust and the 3' RMR test pipe and i got my ECU xflashed or reprogramed by Vishnu... What would be the next best upgrade, should i go with the Vishnu stage 1 with the Cams and cam gears and new fuel pump, has anyone used Vishnu or if its a good way to go??
thanks..
Old Mar 14, 2006 | 02:13 PM
hotrod2448's Avatar
Search.
Yes, cams and a fuel pump are a good next step if you are wanting more power. If you're happy with the power think about a rear sway bar and coilovers.
Yes, Vishnu is a good company that gets good results.
Bdub25's Avatar
mbc and a boost gauge. Do some supporting mods before you get into the cams.
Old Mar 14, 2006 | 02:20 PM
roadace's Avatar
I just did Cams (and fuel pump) and I couldn’t be happier.
That’s your next step.
Old Mar 14, 2006 | 02:25 PM
32 psi daily's Avatar
mbc, boost gauge, egt, cams, cam gears (depending what you run), walbro fuel pump, intake (if you must), bov with stiffer springs, then you get into wideband, injectors, turbo, manifold, o2 housing, pistons, vales, rods, etc.
yeh, get a boost gauge man, if you don't have one yet.
that and mbc.
Then cams.
tune....
THEN LAMBO DOORS!!!!!!!!!!!!!!!!!!!!!!!!!
WITH 22Inch RIMS!!!!!!!! and NEONS!!!!!!!!!!!
Old Mar 14, 2006 | 02:31 PM
TxEvo8's Avatar
You ought to come to the NTEC meeting next Tuesday. You will see many Evos in various states of modification and will get as much information as you can handle form us. You can get test rides and learn from our mistakes on what works and what doesn't. There is a thread in the South Regional forum about the meeting.
Jaylenospoolboy
57
Jun 2, 2006 09:48 PM
evo ippo
18
May 18, 2006 09:33 PM
EvoSam
24
Oct 26, 2004 09:37 AM
Speedlimit
10
Aug 13, 2003 01:35 AM
