Part of boost problmes leading to Forge mbc
Old Mar 20, 2006 | 10:39 AM
EVIL_EVO_VIII's Avatar
Originally Posted by fsugatorbait
Everything worked fine before the o2 housing install, correct? If so why dont you want to believe it's the o2 housing? Afterall you saw how many others are experienicing issues with theres.
Yes everything worked fine but what is making me think its the mbc is that sometimes im unable to lowe the boost effectively. Like for example: I make a wot pass and it spikes 23-24 psi, i turn it down and it still boost the same, i once again turn it down, make another pass and it barely goes down, i make one more wot pass and then its low, then sometimes it goes back up by itself! This is what i dont get
Old Mar 20, 2006 | 10:50 AM
kekek's Avatar
Think about it for a minute. If you are getting boost creep then lowering the MBC setting won't have any effect until you drop below the boost creep's upper threshold. Make sense?
I realise that changing the O2 housing is a pain, but I don't think anyone in your 2 threads has pointed at the MBC yet except for you.
Old Mar 20, 2006 | 10:57 AM
JuancaROD's Avatar
What you're describing is what I experienced a few months ago. Changes on the MBC setting didn't work as expected. I solved the problem by cleaning and greasing the spring and ball on my Unos. I still think that the ball should be a little bit bigger, it was getting stuck so bad that it took me quite a while to take it out of the MBC.
Old Mar 20, 2006 | 10:58 AM
Well, you got a point. Just for assurance, ill clean the mbc to see if that helps, if not then ill move to the o2 housing or the wga
Good to see im not the only one with this problem. What exaclty was happening to your car?
Old Mar 20, 2006 | 11:15 AM
KazzEvo8's Avatar
Originally Posted by cij911
There have been a number of reported problems with the MBC. That said, when setup and working properly they seem to be quite good with the VIII.
I have a IX with an MBC and am not completely sold on the setup -- I would rather have the ECU and EBC do the work.....
... you can let the stock boost solenoid do the work with a Works flash ... it uses the stock boost solenoid, no need for an MBC. Just tell 'em the boost you want to run...
Old Mar 20, 2006 | 08:49 PM
JuancaROD's Avatar
High boost spikes, about 25-26 PSI. Re-setting the MBC was not consistant, sometimes boost was too low and sometimes it was still high. The problem was solved completely after lubing the spring and ball.
Old Mar 21, 2006 | 05:23 AM
Thats the same problem im having!! And its only occasinal or when its cold out, ive heard of the ball getting stuck at low temps
Old Mar 21, 2006 | 05:28 AM
eve-slow's Avatar
Did you try cleaning and lubing the UNOS yet?
JuancaROD's Avatar
I live in Miami and temp. doesn't change too much, so I don't think low temps will cause this issue. Clean the ball and lube it pretty good.
Old Mar 21, 2006 | 05:30 AM
I will tomorrow when im off of work, and ill let you guys know what happens
Old Mar 21, 2006 | 05:32 AM
eve-slow's Avatar
Ya, it only takes a few minutes. I'm eager to see if that is really the problem.
BADEVO's Avatar
Miguel,
Why not just contact Luis he's right there in Orlando with you?
Just a thought.
Dan
Old Mar 21, 2006 | 05:35 AM
Originally Posted by BADEVO
Miguel,
Just a thought.
Dan
Ive tried contacting Mike more than a few times, and no replies at all! Im surprised either one of them have posted here about these issues with this mbc. They know this is a common problem. I was told by Mike to contact him if i ever had this issue and i get no responses at all. Ill probl end up taking this mbc off and buying a hallman or something else bc i need to get this fixed soon!!
Old Mar 21, 2006 | 05:39 AM
eve-slow's Avatar
I'm telling you bro, don't get rid of the UNOS. Once cleaned and lubed, its the best on the market. Also, don't forget about the possible o2 housing problem. Are you just hoping and telling yourself it couldn't be that issue?
Old Mar 21, 2006 | 05:48 AM
It might be the o2 but, like i mentioned the boost doesnt adjust properly when i turn it down, seems like its getting stuck, its giving me crazy spikes causing me hit fuel cut just like how others here have experienced
