?? for those with the Ebay o2 housing?
Old Mar 20, 2006 | 07:22 AM
EvoTech's Avatar
This weekend I installed the ebay o2 housing as well as a new turbo and my ported exaust manifold. I can now hear the turbo spool up like a jet plane. The first time I heard it I thought it was a police siren behind me. That is exactly what it sounded like. Has anyone else noticed this? I have the stock airbox so I may hear this noise more than those with an aftermarket intake who have always heard the turbo.
Old Mar 20, 2006 | 07:25 AM
Az3ar's Avatar
You have a boost or exhaust (after turbo) leak.
Old Mar 20, 2006 | 07:33 AM
EvoTech's Avatar
Boost is rock solid. Does not sound like an exhaust leak.
Old Mar 20, 2006 | 07:38 AM
kevo's Avatar
Hey Ed, I had the ebay 02 on for a few days, it louder than stock o2 but its sound more like air rushing in rather than a siren sound. Usually a high pitch siren sound is a bad indication of a turbo going bad, hope this is not the case for you.
Old Mar 20, 2006 | 01:27 PM
matt55's Avatar
Boost is rock solid..
What does that to do with a boost leak ?
No more or less noise after the O2 install for me .
Old Mar 20, 2006 | 01:32 PM
Stinkapuss's Avatar
Same here.
Old Mar 20, 2006 | 01:39 PM
dubbleugly01's Avatar
no extra noises when I installed the 02 housing. What type of turbo did you install? One of the aftermarket 9-20G's makes quite a bit of noise. I forget if it was the five blade impeller or the six blade that makes the noise, but there is at least one thread on it.
Fireball's Avatar
Originally Posted by Stinkapuss
Same here.
Me 3.
Old Mar 20, 2006 | 02:24 PM
use2vtec's Avatar
Sounds like a pretty bad exhaust leak. The only way you will hear the turbo spool like that is through the exhaust. Even if you have a exhaust leak that wont make you lose boost at all, has nothing to do with holding boost. I did the ebay o2 housing and I cant hear my turbo spool anymore or less than I could with the stock one. A exhaust leak would be pretty noticeable though.
