View Poll Results: Which Cams would you prefer to have for bigger power with bigger turbos
Revolver Cams
21
75.00%
HKS 280
25.00%
Voters: 28. You may not vote on this poll
revolver cams vs Hks 280 cams
Old Mar 22, 2006 | 09:40 PM
FastEvoFL's Avatar
Im wodnering if anyone has done 280s with Emanage?
Old Mar 23, 2006 | 03:54 AM
EVO8LTW's Avatar
Originally Posted by Soon2BEVO
Everyone keeps using that Buschur example of how he made more power and torque, and Im not doubting the Revolvers potential to make more power because I think they should, but if you read carefully the car was also running 2 more PSI so what they will do at the same boost we still dont know. We can only speculate until a controlled test is done.
Can you post a link to the post that you are talking about?
Maybe the cams raised the knock threshold sufficiently to run 2 more PSI without knock, in which case you could fairly attribute the related gain to the cams?
Old Mar 23, 2006 | 05:41 AM
Evo8Master's Avatar
Originally Posted by 1StockEvo
GT30R w/AEM and Revolver cams,valve springs and retainers here. Loving every moment of it.
How does she idle with the revolvers and Aem Ems? Hows the spool up for daily driving? Good for daily driving?
Old Mar 23, 2006 | 07:58 AM
Soon2BEVO's Avatar
I dont think so at all. Search for the thread yourself, I have a terrible hatred of searching for threads on these damn forums, seriously! It was when Buschur switched his 280s for the Revolvers, he made around 17-25whp (somehwere inbetwen there)and like a crazy 50 ft/lb of torque. The dyno with the 280s was 26psi while with the Revolvers he mentioned further down he was cranked the boost to 28psi.
I think everyone got a little Revolver cam crazy after seeing that but I highly doubt the gains would be near that large without the 2psi extra, however like I said before, I think there will be gains, just not that dramatic. Id like to see someone do a controlled A/B test (like TedB might do)... and if he uses cam gears that'd be cool too.
Old Mar 23, 2006 | 09:25 AM
Gsxfury's Avatar
Yeah I would be interested in a similar test to see what the gains are at the same boost level and mods and everything else
Old Mar 23, 2006 | 10:52 PM
1StockEvo's Avatar
Idle is a little lopey but not to the point of the car dying. Sounds nice and chunky. These cams in my own personal opinion are great all around cams from bottom to the top of the rpm range. I am enjoying my set up I have yet to finish fully tuning the car but on my base tune I made 359.1 awhp and 326.3 awtq on 91 octane and @ only 22.03 of boost on a Dyna Pack dyno. Also this is with my old style exhaust manifold. The new exhaust manifold spools the turbo up about 300 rpms quicker and hopefully I will have the charts to that up within the next few weeks.
Old Mar 23, 2006 | 11:04 PM
DSMBRETT's Avatar
Revolvers are the best cams on the market for the 4G63. Better torque band then HKS, JUN or
GSC, and more top end power as well. They do need tuning and are not a slap them in and forget it deal. But that is what you would expect out of these high lift cams. They sound awesome at idle as well!
ilikeppie
11
May 22, 2012 01:49 PM
Johnboy1065
17
Nov 19, 2007 11:11 PM
Coloevo
14
Feb 24, 2005 06:50 AM
Robbyh
15
Dec 10, 2004 06:36 AM
rACerS
Feb 19, 2004 04:50 PM
