gt3076r and plug gaps
Old Apr 2, 2006 | 11:27 AM
BSREVOLUTION's Avatar
im running a gt3076r set up with BPR8ES plugs. i have gap them at .26, anyone what to let me know what they are gapping thiers at?
and on 110 leaded, what is the max boosted your running with a gt30r kit? thanks justin
Old Apr 2, 2006 | 11:33 AM
jj_008's Avatar
I gapped my BR8ES at .023 and have ran 30psi on 100oct w/ my old GT3076.
Old Apr 2, 2006 | 11:39 AM
asasin79's Avatar
i used .025-.026 also.
Justin, did you get the dp? how did the "box" hold up?
vin
Old Apr 2, 2006 | 02:20 PM
very good vin. i havent even taken it out yet. if you can give me a call. im have some problems with boosting over 25psi.
Old Apr 2, 2006 | 05:55 PM
CBRD's Avatar
i had serious misfire problems at .28 on my 35R, and now at .22 im working well, even at 32psi.
stock coilpacks.
my 2 cents
cb
Old Apr 2, 2006 | 07:44 PM
curt, are you using the stock wires? i just took my magnecor wires off and put the stockers back on. i have not test it yet but will tomorrow. and ill regap my plugs to .22 thanks justin
Old Apr 3, 2006 | 05:36 AM
GTVEVO's Avatar
I run .022 for the best results on the stock ignition. Each car seems to be different, you will most likley be able to push the limits of the stock ignition too so keep that in mind.
Old Apr 3, 2006 | 06:12 AM
Ted B's Avatar
HKS DLI II fixes that issue.
Old Apr 3, 2006 | 03:17 PM
MattGold's Avatar
Sounds like closing the gap a tad does too.
Old Apr 3, 2006 | 05:50 PM
Ted B's Avatar
True, but 0.28-0.29" isn't a very large gap to begin with, and a 25% reduction in the gap (e.g. to a 0.21-0.22") is a fairly sizable 'tad'.
A smaller gap results in a shorter duration, weaker spark, which tends to go in the wrong direction where burn efficiency and power is concerned. This is the reasoning behind aftermarket products that improve spark energy and duration (e.g. MSD). In this case, it's a matter of the factory ignition not being capable of handling cylinder pressures far in excess of what the factory intended as opposed to the specified gap being too large.
Old Apr 3, 2006 | 06:19 PM
GTVEVO's Avatar
Ted every time I listen to you I end up spending money, but at least its for a good reason and good results.
Old Apr 7, 2006 | 06:20 PM
WrX Kila's Avatar
hmm interesting! I am running the br7es ar those ok?
SpeedI2acerX
13
Nov 4, 2016 01:40 PM
bevolucion
Dec 15, 2009 04:55 PM
Pure Playaer
Nov 29, 2008 12:59 PM
Johnboy1065
11
Jan 14, 2008 05:37 PM
riceball777
Feb 6, 2007 09:28 AM
