Perrin Test Pipe Question
Old Apr 4, 2006 | 09:46 AM
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
Hey call me a moron but I just got the perrin test pipe used and had a question about the install. I have the O2 sim that installs inside the car, but isnt there an o2 sensor that goes in the exsisting cat now? what am I supose to do with that? remove it ? or tie it up somewhere?
Old Apr 4, 2006 | 09:55 AM
PDXEvo's Avatar
The O2 sensor goes after the cat. There is a bung already on the Perrin exhaust system to attach the O2 sensor too. If you have a different exhaust, then I dont know if you will already have a bung or not.
Old Apr 4, 2006 | 09:58 AM
jj_008's Avatar
The test pipe you bought is for an EVO 8. Evo 8's don't have the O2 sensor in the cat.
Old Apr 4, 2006 | 10:40 AM
M3this's Avatar
But the IX dose?
I havnt looked yet I was just guessing it did and wanted to make sure I have all the correct info before doing the install.
Old Apr 4, 2006 | 10:41 AM
Rnm's Avatar
Rnm
The IX's have the secondary o2 sensor in the cat.
EnJaNir's Avatar
From what I understand
8: Secondary o2 sensor is in the bpipe
9: Secondary o2 sensor is in the cat
Old Apr 4, 2006 | 10:43 AM
thetox's Avatar
correct. the IX O2 sensor is in the cat and the VIII is in the downpipe. However if you are using an VIII downpipe there is enough wire connected to the O2 sensor that you could just about pull it up to the turbo(told this by someone from vivid racing). You will have plenty of room to pull the O2 sensor to reach the bung in the downpipe if that is the route you want to go.
Old Apr 4, 2006 | 10:44 AM
M3this's Avatar
S_hit ... then will I not be able to use it on my car? i thought they where the same.
Old Apr 4, 2006 | 10:48 AM
M3this's Avatar
you sure about that ... I got the DP and and test pipe off a guy that ran it on his VIII ... but the test pipe nor the downpipe have a place for the O2 to screw into.
Could I just unplug the O2 that goes into the cat since I'm using the O2 sim ?
Old Apr 4, 2006 | 11:02 AM
M3this's Avatar
Just called Perrin ... the test pipe will not work on the IX
The newer ones will, but the one I have will not.
Old Apr 4, 2006 | 11:42 AM
EnJaNir's Avatar
I believe the primary o2 sensor is in the o2 housing
There is no o2 sensor in the downpipe
Just what I stated before
8: bpipe
9: cat
Old Apr 4, 2006 | 11:46 AM
M3this's Avatar
Test pipe for sale if anyone is looking for one ... check my sig.
Old Feb 21, 2013 | 10:39 PM
WikdEvo's Avatar
I know this is a super old thread but i'd rather post in here as it is for the same reason. Would the 8 test pipe work on the 9 although it doesn't have a spot for the 2nd o2 sensor? That 2nd sensor is just to check if the cat is working anyways right? Couldn't you just zip tie up the second sensor out of the way and install the pipe?
EvoX777
Jul 24, 2009 01:35 PM
dirty0513
South Region
Jan 21, 2007 02:59 PM
mcbrown35
Lancer Aftermarket Forced Induction Tech
Feb 24, 2005 07:20 AM
ZyBeR
Sep 19, 2004 05:22 PM
Ethan
Jul 16, 2003 05:42 AM
