ACT HD Extreme plate - Act Flywheel
I just had this recently installed and i have a few questions. The first is i know the clutch pedal is suppose to be stiff but at a stop i have to nearly push the clutch down to the floor to get it to engage 1st. Probably about 3-4 inchs from the floor, i suppose its pass' the half way mark of pushing the pedal. IS that normal? Its the same for the reverse. Now when going to 2nd - 5th gears its way less pedal action and harder to shift it into gear. Is it suppose to be a ***** like this?
No. Adjust your clutch peddle inside the car. there is a nut on an adjuster bolt. MAKE SMALL changes. it is very sensitive. I would say don't go more than 1 turn. I would go 1/2 turn (180 degrees) and see how that is.
red_evox_87
Mitsubishi TC-SST Discussion
Jun 13, 2016 09:00 AM
rcboosted
Apr 18, 2011 05:47 PM
thanks
