Vishnu vs Buschur and Al.......I LOSE!!!
Originally Posted by Zeus
smokedmustang, you still want your thread closed?
...and kudos to those of you who have kept this civil.
In other words, does the extra parts = MORE power? That is the gist of the thread!!
Originally Posted by GGEVO2k5MR
I was the 05 MR that smokedmustang was racing...I have Buschur's stage 1-4 w/ GSC 272's
exedy twin HD, Forge wga, race fmic w/ licp and a custom dynoflash from AL....i would like to see 11's on pump, but jumping from BR stage1 to stage4 w/ no race time in between....I have to learn how to drive the car all over again. All in all it was for fun had a great time. I know I will improve with a little more adjustments here and there.
Hey Doc we need to do the grudge matching again it seems as though we get through the staging lanes a little faster.
Luke where were you? y the no show?
Lots of $$$ thrown at a car doesn't always mean big HP #s...
and big HP #'s doesn't always mean quick 1/4 mile times.....
You still heave to know how to drive......
and only in an evo forum would people be disappointed with low 12's..... you people are really jaded...
and for the record....
a great example to all the people who say drag racing doesn't take skill..............fools.....
Smoked, your car is a frankenbeast ... IMO you need to take some time-out and get it all sorted out. Get that alky kit hooked up and working, check everything over ... twice ... and then get'er tuned. If you still have the XEDE hooked up, you can also enable launch control - erm, just for the cool sound, of course
l8r)
l8r)
l8r)
l8r)
Smoked ... I'm actually glad you posted. You brought up quite a few ideas in a nice format, that is comparatively, very easy to understand. To broaden out the subject a bit, let me make a quick say on gas types and tuning.
My tuning days (as small and incremental as they are) stem from motor bikes. My first and most substantial tuning tuning endeavor was a Suzuki SV650S. Its a 650cc V-Twin. My second was a TL1000S ... which is a 1000cc twin cylinder. Both run over 11:1 compression ratios. (Suzuki's faith in piston, head, and chamber designs). What I found was, once tuned for a certain grade of fuel, going down in fuel grade caused detonation or more likely harsh(er) running, but going up didn't really net any better performance.
On these paticular bikes, in stock form plus a K&N and exhaust, I first felt best performance on 87oct. Not 85, 89, or 91oct, it was definately 87oct. Then I got to run my TL1000S on a dyno for a tune. The first thing the dyno tech. noticed (on that 70deg. day) was my TL was running a little more power (a mere 2hp more than usual TLs, but that's quite a bit to a bike tuner) and he asked why. I mentioned he might be seeing 87oct. gas instead of 91oct. He then optimised some parameters, mainly for power output smoothness which is a known TL1000S problem. Suzuki actually does a pretty awesome WoT tune on their bikes.
The moral of the story is if you tune to a paticular gas profile, once you up the octane way up, you run into not being able to fire off the gas hardly at all and end up with probably less power produced across the rev. range. Leaded fuels are even worse. Their effective octane goes through the roof and their burn profile is significantly different than pump gasses. Hopefully my 'other motors' example helps put octane and performance into a better perspective. That and I be DROOLing that you have a TME Turbo.
Good Luck, .. let us know soon how the tune goes.
Best Regards,
Cheers,
~j.
P.S. Best frontline reference on octane I could come up with, and a well-written read at least: http://en.wikipedia.org/wiki/Octane_rating
Best Regards,
Cheers,
~j.
Last edited by jcnel_evo8; Apr 12, 2006 at 04:13 PM. Reason: Weird ... Misplaced Sentence. -- Wiki' Reference
Originally Posted by DynoFlash
I would hate to disagree - but I must
We have tested pump gas vs. race gas many times on the dyno and the variation in power and a/f is nearly unmeasurable
Best Regards,
Cheers,
~j.
Best Regards,
Cheers,
~j.
Originally Posted by shiv@vishnu
But frankly, we don't even recommend leaded gas as it is too hard on the ignition system.
-shiv
-shiv
Originally Posted by mike 99gsx
I was wondering if you could clarify this? How is leaded gas hard on an ignition system?
I have been told to RUN the gas you were dynoed on!! ie if 110 leaded, dont put in 109 Unleaded and expect the same results!
Originally Posted by smokedmustang
I think it burns hotter, and messes with the plugs and the O2 sensors. On a side note. I have driven my car with 110 LEADED for 30, yes thirty thousand miles!! (30,000) without having a problem with the O2 sensors, or the O2 on my AEM UEGO gague! Guess I was lucky. I think the leaded and unleaded have different burn characteristics.
Anyone who wants to see just how differently race gas burns just needs to try to start up their car first thing in the morning and see not how long it takes to achieve a stable and clean idle. Leaded gas has its place but there is a reason that fewer and fewer people are using it these days. And it's not just because of the toxic poisoning effects.
-shiv
I know what leaded gas does to O2 sensors and spark plugs. I would like clarification from Mr Vishnu on how it stresses the actual ignition system (I realize plugs are part of the system but I don't think any performance enthusiast gives a crap about replacing spark plugs in one of these engines).
If you don't think that the spark plug is an "actual" ignition system component, then I guess we found the source of the confusion. If you don't give a poo about changing plugs, that's cool. Me? I'd rather drive.
shiv
Originally Posted by Smogrunner
Actually, the one thing I don't see being written is simply "Good job" to both Al and Noize. Al, your tune obviously is making good power, so
to you. Smokedmustang, although you lost the race, your car is obviously making good power as well. You are both doing 10 mph over stock so way to go.
question: what happens if you put vp109 to a 100oct map?? do you loose power or is the difference insignificant??
