driving on a slipping clutch
Old Apr 14, 2006 | 10:43 AM
turbo4's Avatar
the exedy was by far the greatest clutch on earth
Could you be more specific about what you preferred about the Exedy over the ACT?
Old Apr 14, 2006 | 12:01 PM
Silver Knight's Avatar
Originally Posted by BigAeVo
Sup everyone, my clutch is currently slipping pretty bad right around 3 k rpm it will slip this is after going to the track , i dont have the money right now to get a clutch the one i want is the exedy twin disk cerametallic and that costs a pretty penny and thats not even with installation. Is it ok to drive around and baby the car? Or should i leave it in the garage till i get enough money to replace it.
My clutch started slipping 3 weeks ago and as long as you as you stay outta the boost like previously recomended you'll be ok. I even abused it last weekend thinking I'd have my new clutch in earlier this week and it's still driveable, BARELY, but driveable.
Old Apr 29, 2006 | 08:33 AM
dan l's Avatar
They may be good, but not THAT good. No one in their right mind would run an ACT 2100 with a 500+whp car. ACT doesn't even use the 2600 anymore...now, they're all 2900s. I'm sure Dirk wouldn't recommend a basic ACT HDSS for a car with that much power either. That just doesn't make sense.
$1500 for a twin disk that can hold more power, launch harder, shift smoother, withstand more abuse, and includes a lightened flywheel is worth it...
They make 2100, 2600, 2900, and possibly others. Also, I assure you I am in my right mind. I've had my 2100 clutch for 3 years and 60K miles now. Last fall it held a 126.8mph pass so I decided to keep it for this year but replaced the stock disc with one from another manufacturer because I wanted to try something new. It held a dozen passes on the slicks at the track, about 12 street tuning passes, and 20 or so non slick tuning passes. Then I raised the boost to 32 psi and layed into it in 4th gear and it shook, shuddered, and then blew off. I have no complaints, that was enough power for a 130+ pass on a 3 year old abused pressure plate that no doubt probably acts more like a 1900 lb plate due to the heat.
So what am I doing, putting in an ACT 2900 PP. You just can't beat the relibility, cost, and smoothness of these units. I like composite discs a lot!
Originally Posted by ACTman
Just keep making a good product that people can rely on at the price you offer. In the evo world buyers often think that more expensive is better. I love your flywheel, pressure plates, and discs. I'll go back to your disc when I wear this other one out. Its not that I hate the disc that I have now, it just needs to get warm to work. I've done second gear launches, sidestep full boost slips on the highway, and tons of other stupid things and your disc just loves it. Sorry I couldn't get a 130+ pass on the 2100 though .
Old Apr 29, 2006 | 05:52 PM
TurbotrixRacing's Avatar
We wont use anything but ACT ... awesome clutch.. Customers love it .. no rattle noises when clutch depressed. ACT has lead the DSM market for years and years, and the evo is no different..
Mark
Turbotrix
Old Apr 30, 2006 | 08:56 AM
Dingo7's Avatar
wat about this act man if i get a act 2900 can i reuse my stock flywheel? to give u an example stock clutch and 37000 miles and still holdin strong but know it will need it 1 day. can the stock fly wheel be resurfaced and if not wat fly wheel is better for the street?
Old Apr 30, 2006 | 10:00 AM
ACTman's Avatar
The stock flywheels are very good for a stock part. Mitsu uses the right materials (not gray iron) so they are safe and even if raced/overheated/thrashed they are not going to blow up. The stock flywheel is pretty thin behind the disc though so if you tend to abuse the clutch the stock flywheel is more prone to warpage than one of ours, especially our Streetlite version which is 50% thicker behind the disc. Just make sure that whoever resurfaces the stock flywheel does a good job. I am always leary about other people's work, because I have seen shops ruin perfectly good parts by "rebuilding" them. But there are other shops that do awesome work.
Old Apr 30, 2006 | 08:48 PM
86gti's Avatar
stay out of boost, slow on the gas, and keep it in lower gears for less load
asu11
Feb 5, 2014 05:18 AM
MitsuJDM
23
Feb 23, 2013 02:07 AM
evoch3n
10
Jul 29, 2011 10:32 PM
RPRalliart04
15
Apr 8, 2009 04:04 PM
bluej20
11
Dec 18, 2007 09:46 PM
