Synthetic gear oil?
Old Apr 9, 2003 | 02:50 PM
flybyevo's Avatar
Synthetic gear oil?
I am fast approaching 1,000 miles and will change the engine oil very soon. I just ordered filters from my dealer that were UPS'sed to the house. I am ready to rolll.....
Question is this: Should I change the factory gear oil to synthetic?
I did that with the Galant when new also. Seems like the right thing to do. I did have to rebuilt the transmission at 138k but I don't think it had anything to do with the gear oil.
What are the thoughts of the forum?
Old Apr 9, 2003 | 04:46 PM
jemm's Avatar
Thumbs up
http://www.lancerregister.com/faq/M04/m04.html
Generally, for all Evo’s, use the best fully synthetic GL5 rated oil you can find for all the drivetrain (this does not include plated LSD’s or the AYC system as these require special oils). The Evo 4-7 gearbox requires 75W/85W rated gear oil. Please note that the service schedule for the Evo’s usually state anywhere from 26,000 miles to 45,000 miles for replacing the gearbox, transfer box and rear diff oils however, it is recommended on such a high performance car that these oils are changed sooner. Consider changing them every 9,000 miles to 13,500 miles or once a year. The cost is very small (£30-£50) and you will often find that the gear change becomes better when the oil is first changed on a new car.
Old May 12, 2003 | 12:30 PM
Dubai_EvoVII's Avatar
Hi I got an EVO 7 ..
And I got the car for about a year now.. the car did not run much it ran less than 10,000 KM that is less that 6,200 Miles but I can feel that the gear box is a bit rought.. It might be the clutch also .. but still I want to be safe and change the gear oil .. any idea where can i get it from ???..
Thanks
Old May 12, 2003 | 11:52 PM
flybyevo's Avatar
Thanks
I don't know where to find it if you are outside of the US. Here in the US we can find it at almost any auto parts store.
I have always used Mobil 1 in the crankcase and gearbox and anywhere else it is needed...
Flybyevo...
Old May 15, 2003 | 02:05 AM
typer77's Avatar
I can get some goodies here like hks or superautobacs. ;P if I can ship it, I would get you some..
Old May 15, 2003 | 02:12 AM
typer77's Avatar
Old Aug 10, 2003 | 06:27 AM
Shadohh's Avatar
okay, sorry dood but you are wrong.
please disregard what he said.
the evo tranny requires gl-4 fluid.
Gl5 fluids have additives such as sulfur which eat yellow metals such as brass and bronze.
brass and bronze is used in the Evo tranny syncros.
so your gl5 fluid will end up killing your syncros in 10k-20k miles.
mobil1 even has a data sheet on it on their website about it.
best fluid to use is redline MT90
Old Aug 10, 2003 | 06:44 AM
jemm's Avatar
Interesting! great info info there Shadoh.. the dealer down here uses "Valvoline High Performance Gear Oil GL-5 SAE 80W-90". Thanks for letting me know about this problem.
Old Aug 10, 2003 | 07:14 AM
berkel's Avatar
Copied from my tech forum post:
Hi all,
I just put NEO RHD in my wife's WRX tranny and rear diff and it helped tranny smoothness quite a bit. There is a lot of info and controversy on the WRX boards about some synthetic gear oils being too slippery.
In our EVO, they recommend a GL-4 oil for the tranny and GL-5 for the diffs, right? I may put Redline MT-90 in the tranny, since I believe MT-90 is GL-4,right? I love the NEO stuff so far, so I may use that in the diffs to see how it works.
I think if the diffs require GL-5, the NEO would be excellent. I had MT-90 in my Integra and it was awesome. On the WRX forums, people had problems with MT-90 since it is GL-4 and the WRX requires GL-5 in the tranny and rear diff...
I will probably do this before 10K miles. BTW, any idea if this will help decel noise at all?
Thoughts?
FB
__________________
EvoKnievel77
Jan 27, 2017 07:54 PM
Lancer905
Toronto Lancer Club
Nov 29, 2010 02:47 AM
_EVOlved_
36
Jul 24, 2007 11:57 AM
AhmadHasib
May 1, 2007 12:36 AM
Ph3n1x
Apr 2, 2007 01:38 PM
