DC manifold and tapping EGT sensor
I plan on buying a DC manifold and tapping it for an EGT sensor on the runner #2 (2nd from the passenger side, correct?) about 2 to 3 inches away from the head.
All my searches say this is the best location! Is this correct?
My other question is: Is this a good manifold?
Seems better than stock from the dyno graphs and I don't plan on upgrading turbos at all. Searches don't bring up any bad comments about it. I would like to see a comparo between ported manifold and it, but have not - thus far.
The DC manifold makes sense based on my goals with the car: I plan on basic bolt-ons and upped boost with EBC and flash and calling it a day. I don't want to overdo things with this car. Just make it look decent, drive decent and easy to maintain. I don't want a tuning headache, I have no time for that.
Everyone has different goals and I respect yours, so please do the same for me!
So, if this a bad choice, then I will lay off it, but any sound advice is greatly appreciated!
Thanks!
Everyone has different goals and I respect yours, so please do the same for me!So, if this a bad choice, then I will lay off it, but any sound advice is greatly appreciated!
Thanks!
The gains look impressive down low.
As to where to put the egt sensor, my advice is to have it installed where the weld will be good & the replacement of the sensor is easily accesible.
IMO where the egt probe isnt to important on such a short run of a primary pipe.
In my experience of high revving n/a & turbo engines, the closer you place the egt probe to the cylinder head, the sooner the probe & or the welding of the bung to the pipe will fail due to vibrations.
Good luck
Good luck
Essentially you want to put the sensor on the hottest cylinder/runner, an overall temp reading is nice, but there is a loss in heat from the begining of the runner to the end of the collector. Find the hottest cylinder/runner (search) and place it 2-3" away from the flange.
Tap a tubular manifold? I am not sure if this is a good idea. I have never tried it beacuse I just weld them on.
What is the manifold 16 gauge? doesn't seem thick enough for a tap to me.
Ben
Ben
Ben
Ben
