Cleaned maf (now runs like crap)
Old Apr 23, 2006 | 07:40 PM
Amazin' Wasian's Avatar
well i cleaned my maf today with electrical contact cleaner. let it dry all day, then when i drove my car its started and idled fine, but when im about to hit boost my car just cuts out for a few seconds. I cant even rev my engine to make boost in netrual. As soon as my boost gauge hits 0 it cuts out.. What happened and how can i fix this? please help, thanks
-nick
Old Apr 23, 2006 | 07:46 PM
thatsMR2u's Avatar
you made sure to plug it back in right?! if not try resetting your ecu with the negative battery terminal
Old Apr 23, 2006 | 07:48 PM
yes its plugged back in.....and my battery cable was unplugged the whole time the maf was off the car, i hooked my cable back up after i reinstalled my maf.
Old Apr 23, 2006 | 07:49 PM
Warrtalon's Avatar
Yeah, make sure the MAF plug is connected. I know you connected it, but make sure it's 100% SEATED. I had that happen to me once...I connected it, but it wasn't completely latched.
If that's not the case, you may have damaged the MAF. Can you switch yours out with another local Evo just to make sure?
Old Apr 23, 2006 | 07:59 PM
yeah its 100% connected...... Yeah i guess ill switch it with a local evo guy to see if that helps..... Im pretty sure it isnt damaged tho....i never touched the sensor just sprayed and let dry...what else could the problem be?
-nick
Old Apr 23, 2006 | 08:46 PM
thatsMR2u's Avatar
i know when i clean my maf sensor I was told I needed to use non-chlorinated brake cleaner - and im assuming that electronic cleaner is also non-chlorinated- but check the bottle to make sure... Also you say u let it dry all day- it should have dried almost right in front of your eyes since its almost pure alcohol- you may have soaked it to much...
Old Apr 23, 2006 | 08:49 PM
Saikou_kun's Avatar
Don't ya hate it when you perform proper maintenance and that winds up messing things up ?
4-BNGR's Avatar
2 questions...
1) Why was your MAF "dirty"
2) WTF is electrical contact cleaner
Old Apr 23, 2006 | 08:57 PM
Nad1370's Avatar
I just cleaned mine with a non-flamable Brake cleaner and blew a little compressed air at it to dry it out.
No problems.
I think you need to clean it again and blow a little air to it. There could be a film residue covering the sensor causing it not to read correctly.
Old Apr 23, 2006 | 09:39 PM
WICKed'N'EVO's Avatar
No problems.
If that doesn't work, then you need to put the dirty stuff back in there!!
Old Apr 23, 2006 | 09:58 PM
Danny23's Avatar
my friend hade the same problem on his 03. he used brake cleaner and let it dry, it drys fast and had your problem. he took it apart again and this time used contact cleaner,(sprayed the crap out of it). and hooked it up and it ran fine again. hope you have the same luck. BTW contact cleaner should dry almost imediatly, even faster than alcohol
Old Apr 23, 2006 | 10:36 PM
nightwalker's Avatar
The ONLY proven way to properly clean a maf without jacking it up is with a q-tip and rubbing alcohol. I have seen mafs get messed up by spraying it with brake cleaner, carb cleaner, and that electric cleaner.
Old Apr 23, 2006 | 10:39 PM
DynoFlash's Avatar
As the 03 evos get older we will be seeing this condition more and more - the solution is to use a oil catch can and using a good air filter
Old Apr 24, 2006 | 08:32 AM
sleet's Avatar
K, so how do you recommend we clean it?
Old Apr 25, 2006 | 04:01 PM
Jamie@WORKS's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=194156
