Invidia Cast O2 Housing (pics)
Old May 10, 2006 | 07:35 AM
  #106
threepointsix's Avatar
Took this at Works last fall.
Old May 26, 2006 | 11:49 PM
  #107
BBYBruno's Avatar
Originally Posted by High_PSI
Since this unit retains the stock mounting and support bracket, could we run a Maxford Manifold or DNP or Megan without fear of cracking them?
I'm going to be running the Maxford(swain coated) with the Invidia 02(swain coated). We'll see how it goes.
Old May 27, 2006 | 08:39 PM
  #108
Zeus's Avatar
Best functional choice in coatings White Lightening is not pretty, but a HUGE difference in temps over all the traditional thin "ceramic" coatings.
Old Jun 5, 2006 | 06:22 PM
  #109
evolved4g63's Avatar
Originally Posted by J8dailo
did the invidia exhaust manifold ever come in production???
http://www.garagegt.com/shop/scripts...dproduct=19803
Not cheap!!
Old Jun 6, 2006 | 04:14 PM
  #110
Wheelhaus's Avatar
Originally Posted by evolved4g63
no way... I could have sworn I'd seen it somewhere else for about half that... I'll see if I can find it. And how in the hell would the manifold cost more than the whole TBE? If i had to guess, I bet they're probably charging what they think it should cost, not the standard markup over what it actually cost them.
Old Jun 6, 2006 | 08:41 PM
  #111
EvoIXMR's Avatar
Well, Wheelhaus - lets not forget the full-race manifold. That things costs like a bazillion bux too I am not knocking full-race stuff. Geoff is an old friend!
Old Jun 20, 2006 | 06:03 PM
  #112
WarmPepsi's Avatar
i'd like to bump this with a little review.
Other than the bolts being a pain to do, the o2 sensor cord needing soldering, and the welded over bung (i guess for an egt), I also had a problem getting my downpipe to seal to the unit.
This is a 3" unit. The stock donut will not fit. Using the tapered Copper gasket (ring) that they provide, it did nothing to seal the unit and it was just a load of air coming out. It bottomed out before it ever tried to seal (megan DP).
With no other real option, i did what any half-brained person would try. I turned the ring around.... So it tapered up. this actually allowed the DP to seat against the copper ring, and sealed like a champion.
Just thought i'd make note of it for anyone else that has an issue with this part, as it was DEFINATLY not a care-free, perfectly aligned, bolt-on install.
Old Jun 20, 2006 | 06:17 PM
  #113
fsugatorbait's Avatar
Driving impressions?
Old Jun 20, 2006 | 06:27 PM
  #114
Soon2BEVO's Avatar
man that install sounds like a nightmare. Id stick with the ebay 02!
Old Jun 20, 2006 | 06:32 PM
  #115
AlwaysinBoost's Avatar
x2
for as much as this thing costs it should install itself. besides that we dont have a single indepented dyno comparison yet.
Old Jun 20, 2006 | 06:47 PM
  #116
SilverMr's Avatar
I thought D.Buscher was going to do a comparo between the ebayo2,Works o2, and the Invidia o2.He had all of them at his shop a couple weeks ago.Anybody know if he did it or not?
Old Jun 20, 2006 | 06:51 PM
  #117
Soon2BEVO's Avatar
We're still awaiting those results, I dunno wtf he is doing with that. I know he's been busy with the shootout and all. I wonder if he plans to do the testing still.
Old Jun 20, 2006 | 07:22 PM
  #118
WarmPepsi's Avatar
haven't full boosted. Had a hotside issue, and ended up opting for the tme 6.5 (basically a straight replacement) instead of just the hotside, as my hotside wheel had definatly seen better days.
Don't know that i'm gonna feel any real difference in power, but the install and fitament has been an issue.
Old Jun 20, 2006 | 07:31 PM
  #119
Gotcha. Looking forward to your impressions after you've had a chance to test it out.
Old Jun 20, 2006 | 07:33 PM
  #120
WarmPepsi's Avatar
no problem, right now, i was concerned with a burning smell after doing the turbo work... only to realize, it's the anti-seize boiling
that stuff smells GRRRRRRRRREAT.
